Author Topic: Easy AVR USB Keyboard Firmware and Keymapper  (Read 1225140 times)
Offline Ongoe
Re: Easy AVR USB Keyboard Firmware and Keymapper
« Reply #2500 on: Wed, 26 February 2020, 05:08:58 »
Hello everyone, How could I configure a key "One Shot Keys"  in EasyAVR (easykeymap.exe)?
that is, I want to press the shift key once and release it, then press a normal key and
run in capital letters only that first time.
I cant find the solution, :(
« Reply #2501 on: Wed, 26 February 2020, 20:44:11 »
I don't think EasyAVR supports that right now. It's an interesting idea. Basically a temporary mod lock. I'll try and think of something
Sent from my Pixel 3 XL using Tapatalk
Offline ErgoMacros
« Reply #2502 on: Wed, 26 February 2020, 23:37:38 »
Hi,
You may be able to do this with settings in your OS, with "Sticky Keys"
Setable in the control panel.
The "disadvantage" is that it turns the feature on/off for Ctrl, Win, and Alt too.
But, if you press and hold shift like you're doing today, it still acts like a normal shift. So no harm done.
Today's quote: '...“but then the customer successfully broke that.”
Offline Ongoe
« Reply #2503 on: Thu, 27 February 2020, 01:20:06 »
With autohotkey I have a solution
but is not a clean solution, been the keyboard programmable and when changing PC, is easy to loss the autohotkey script.
$shift::
   Input, OutputVar, L1
   Send +%OutputVar%
It is not clean because Input wait for letter key only.
It works but I would like as an smart Easy Avr feature.
« Reply #2504 on: Thu, 05 March 2020, 21:42:01 »
Released version 3.2.1 with this feature
https://github.com/dhowland/EasyAVR/releases/tag/v3.02.01
Offline Ongoe
« Reply #2505 on: Sat, 07 March 2020, 11:25:30 »
Very thankful,  :)
« Reply #2506 on: Sun, 08 March 2020, 13:12:42 »
8 mods?!  Shift, ctrl, win, alt, alt gr...  I guess JIS has different uses for all the right side mods?  More is always better, great work as always :thumb:
« Reply #2507 on: Sun, 08 March 2020, 13:28:21 »
Since the beginning people have been asking for either left or right mods.  This fixes it once and for all.
Offline Ongoe
« Reply #2508 on: Sat, 14 March 2020, 02:28:36 »
Can I use 5 LEDs independents as indicators ?
Using Teensy 2++,
for this options: capital letters, Fn0, Fn1, Fn2, Fn3
« Reply #2509 on: Sat, 14 March 2020, 06:01:39 »
Using Teensy 2++,
I'm not following. Is it a handwired board?
Offline Ongoe
« Reply #2510 on: Sat, 14 March 2020, 07:18:06 »
It is wired same as a Planck, in reality as split planck with 2 PCB for 6x4 keys each, then connected by 2 wires 10 cores with a box that have the Teensy 2.0++ and goes out by USB connector.
I have made before another model hand wired based in same scheme of Planck, wiring is 4x12 in reality, but split too. With Teensy 2.0
My idea is that I can add easily leds to the box of microcontroller.
When testing (learning typing) I have found in some cases that I need info of what layout was active in an easy manner. But dont want decipher blink.
About leds,I need the info, by now the design is without leds.
« Reply #2511 on: Sun, 15 March 2020, 07:35:52 »
I think you can use as many LEDs as indicators as you have spare pins, there might be a limit but it's definitely more than 5 because the GH60 config file (snippet below) uses 5.  The names 'Caps key' 'Esc Key' 'WASD' etc are so you know where the LED is, the next bit is the thing they indicate by default (can be changed in the mapper)
Code: [Select]
num_leds = 5
num_ind = 5
num_bl_enab = 4
led_definition = [
    ('Caps Key', 'Caps Lock'),
    ('Esc Key', 'Num Lock'),
    ('WASD', 'Fn Active'),
    ('Poker Arrows', 'Fn2 Active'),
    ('Fn Key', 'Fn3 Active')
led_hardware = [
#       Port    Pin    Direction
    ( REF_PORTB, 2, LED_DRIVER_PULLDOWN ),
    ( REF_PORTF, 6, LED_DRIVER_PULLDOWN ),
    ( REF_PORTF, 7, LED_DRIVER_PULLDOWN ),
    ( REF_PORTF, 4, LED_DRIVER_PULLDOWN ),
    ( REF_PORTF, 5, LED_DRIVER_PULLDOWN )
Obviously you'll need to change the pins and PULLUP/PULLDOWN depending on your wiring :)
« Last Edit: Sun, 15 March 2020, 07:42:53 by suicidal_orange »
Offline Ongoe
« Reply #2512 on: Sun, 15 March 2020, 08:09:34 »
suicidal_orange, thank you, I think is the info I need
Offline Helspong
« Reply #2513 on: Tue, 21 April 2020, 01:54:38 »
I hadn't used this application in a while, but yesterday i downloaded the latest version to modify a few things on my keyboard.
I encountered a problem though, i couldn't seem to program the hex-file onto my GH60 anymore. Problem seemed to be with the applications used for programming it to the usb.
dfu-programmer.exe wont run: The code execution cannot proceed because libusb0.dll was not found. Reinstalling the program may fix this problem.
I finally found the file online and downloaded it and put it in the exttools-folder. I put my keyboard in the correct mode for programming and ran it once again. Now i get the message:
dfu-programmer: no device present.
Any advice on how to fix this would be appreciated!
Update:
Once i put the keyboard in bootloader mode it turns up as an unknown device in device manager.
The drivers for this device ar note installed. (Code 28)
A service installation section in this INF is invalid
What i did next was that i tried updating the driver automaticly, which gave the same error all over again. I tried it manually and I chose drivers from a list. Choosing the latest one (from 2013) gave the same error, but chosing the older one from 2010 did the trick.
Conclusion: Everything is now working, with older Atmel drivers.
« Last Edit: Tue, 21 April 2020, 11:23:04 by Helspong »
« Reply #2514 on: Fri, 24 April 2020, 13:20:28 »
Update:
thanks for the follow-up.  did you install drivers you downloaded from Atmel?
Offline Helspong
« Reply #2515 on: Tue, 28 April 2020, 11:42:23 »
No problem!
I just browsed existing drivers within Windows itself. To be honest I wasn't completely sure where to find updated drivers from Atmel. I'm sure I would have found them eventually, but since I got it working I stopped looking.
Offline Deacon Cole
« Reply #2516 on: Sat, 23 May 2020, 16:57:06 »
Okay, so I managed to crash easykeymap_windows_3_02_01 I'm not sure what I did, but I was using the define keyboard feature, but I just put garbage in some of it because I didn't have that info yet and wanted to see if this thing will work, so it might have saved that keyboard and now it errors on boot:
cx_Freeze: Application Terminated
OnInit returned false, exiting...
I could bumble my way though this, but now the software won't even boot and I can't find whatever was changed or save to delete it and deleting the entire folder that contains the program and exporting a new version from the zip doesn't fix anything.
What do I need to do to make this work again.
EDIT: Apologies. I solved it with a little RTFM.
« Last Edit: Sat, 23 May 2020, 17:05:58 by Deacon Cole »
« Reply #2517 on: Sat, 23 May 2020, 17:02:44 »
Assuming you're in Windows you need to delete the board's config file from the path below.  If you don't know the answer just enter something that could be right, not complete garbage - errors and error checking are the biggest weakness in this firmware which otherwise works very well.
c:\users\[you]\.EasyAVR\boards
« Reply #2518 on: Sun, 24 May 2020, 13:31:04 »
Even if it was invalid, it shouldn't have crashed like that.
This is what happens when one person writes a sprawling, multi-function app in spare time: unhandled exceptions.
I'll take a look to see if I can make it more robust.
« Reply #2519 on: Sun, 24 May 2020, 15:38:22 »
thanks for letting me know.  I have committed a fix.  Next release should be more robust.
Offline fattredd
  • Way to go
« Reply #2520 on: Wed, 27 May 2020, 10:30:53 »
Is there a way to send modifiers with a tap key? Macro tap keys would work too. I'm trying to have L/R Shift send parentheses when tapped.
« Reply #2521 on: Wed, 27 May 2020, 13:10:13 »
That should work, you'd need to set the key as shift then the tap keycode would be the macro key.  Not at a computer so can't actually test...
Offline fattredd
  • Way to go
« Reply #2522 on: Wed, 27 May 2020, 14:04:58 »
The GUI won't allow me to select a macro key as the tap keycode. Do you think I'll have to edit the json file, 9 or am I missing something?
« Reply #2523 on: Wed, 27 May 2020, 16:51:48 »
You're doing it backwards.  Set the key to be a Shift and then set the tapkey to parentheses.
Offline fattredd
  • Way to go
« Reply #2524 on: Wed, 27 May 2020, 16:59:53 »
I'm pretty sure that's what I'm doing though. Here's a screenshot of the tap code set to '9'. It works how I would expect, but the macro keys are all disabled.
Thanks for your patience. I'm probably just being an idiot.
243656-0
« Reply #2525 on: Wed, 27 May 2020, 17:22:39 »
No, you're not being an idiot.  Tapkeys currently only support alphas.
I think I understand now.  You want parens but of course there is no parens key.  So you get "9".  Let me look into it.
Tapkeys are really just on-the-fly macros.  Might be an opportunity.
Offline fattredd
  • Way to go
« Reply #2526 on: Wed, 27 May 2020, 17:47:12 »
Sweet. Good to hear haha. Thank you!
« Reply #2527 on: Wed, 27 May 2020, 19:49:09 »
By the way, in the mean time, you can hold the other shift key while you tap to get a parens.
« Reply #2528 on: Sun, 31 May 2020, 15:00:27 »
Released v3.03.1
Offline ihab
« Reply #2529 on: Fri, 12 June 2020, 06:59:23 »
Hi
I have recently bought a 60% mechanical keyboard from Deltaco it has a chip nr hfd2201kba and i was wondering if it was possible to re-flash it for more customization with easyAVR? I couldn't find much information on this chip other than a post saying that it might be a STM32.
Hope i can get help her thanks in advanced.
« Reply #2530 on: Fri, 12 June 2020, 07:42:50 »
Hi
Sorry, EasyAVR only works on AVR microcontrollers.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #2531 on: Wed, 12 August 2020, 23:23:00 »
I want to automate a task of "hit control, hit control, hit enter".
I've tried to build a macro of
$LCTRL()$WAIT(10)$LCTRL()$WAIT(10)${ENTER}
and it doesn't work.  Putting it into a tester implies it's only "pressing" control once.
If I do
$LCTRL()$WAIT(10)$RCTRL()$WAIT(10)${ENTER}
instead, the distinct keystrokes are recognized.
I'm curious if this is a faulty configuration on my part, some sort of optimization (if someone enters twenty modified keys in a row, it smashes it down to a single hold-down-the-modifier), or a big.
Overton130, Box Pale Blues.
« Reply #2532 on: Thu, 13 August 2020, 01:17:44 »
That's a really good question. I'll look into it
Offline phinix
« Reply #2533 on: Fri, 14 August 2020, 19:51:07 »
Guys, I hope I won't piss you off with my noob questions here:)
So I got this beautiful QFR keyboard with Forsty Flake.
I would like to add a simple layer to it with pounds sign (board I have is ANSI).
First, I have problem with actual setting things up. Got Flip, got EasyAVR. Now, how can I get this keyboard to be seen by this software?
I understand I need to install Atmel drivers first? Those from Flip folder? How do I do that? I don't see QFR/Atmel keyboard on device list:(
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
« Reply #2534 on: Sun, 16 August 2020, 11:41:57 »
Not at all, though the first answer will always be read the manual :)
« Reply #2535 on: Wed, 16 September 2020, 22:20:17 »
If I do
Confirmed.  It will be fixed in the next version.
Offline TalkingTree
    • My projects
« Reply #2536 on: Thu, 22 October 2020, 11:51:09 »
I'm to defibrillate a dead post to push my luck with RGB LED indicators.
What I'd like to do is to have one or two RGB LED indicators, specifically WS2812B, on my board with Easy AVR.
I know edfan achieved RGB backlighting on pin C  so I assume it's possible to edit the code to have this functionality on a different pin.
I have a very limited python knowledge so I'm not proficient to get there alone.
I know I'm asking much, but has anyone already tried that with success or do they feel like trying?
Thanks.
« Reply #2537 on: Sat, 24 October 2020, 02:55:49 »
Why do you need a complicated RGB LED for an indicator or two?  Standard 4 pin LEDs are effectively 3 LEDs in one and will work fine, if you have the pins.
While it would be great to add RGB to this the reason the pull request was rejected is that it's not flexible enough and only works on port C, I don't understand Python, the LEDs or the chip to know which is the limitation but am intrigued enough to look into it.
Where did you want to connect them?
Offline TalkingTree
    • My projects
« Reply #2538 on: Sat, 24 October 2020, 07:27:55 »
4 pin LEDs would do but they are obsolete technology if you ask me. SMD leds can be daisy chained for multiple usages, such as backlighting as future implementation of both keyboards and software.
I frankly believe that was a coder designer to only go for pin C. If other firmwares can make it work on every pin, why couldn't Easy AVR?
Where as in which pin or what keyboard? In the first case my LEDs are currently wired to B5 and B6. In the latter, any keyboard in my signature.
« Reply #2539 on: Sat, 24 October 2020, 07:41:09 »
Thanks.
I haven't added support for that kind of RGB for two reasons.  First, I don't own any hardware with a WS2812B, so I have no way of testing.  Second, it is a large, complex job to add general support and make it configurable, and I don't have time (two small children).
It's possible that edfan's code would work with the current code base, I don't know for sure.  Adding support in a way that plays nice with the realtime schedule is a challenge.
Offline TalkingTree
    • My projects
« Reply #2540 on: Sat, 24 October 2020, 10:15:08 »
I understand, thanks metalliqaz.
Offline odd
« Reply #2541 on: Fri, 26 February 2021, 17:25:29 »
What did you do to make this work again? I'm having the same issue and I cannot figure out what's causing it.
« Reply #2542 on: Fri, 26 February 2021, 18:03:29 »
Hmm.. I thought I fixed this.  Are you running the latest version?  Are you getting the same Oninit error?  If so, go delete whatever file you made in the config dir in your user directory.
« Reply #2543 on: Sun, 28 February 2021, 04:25:35 »
@odd attach the file here first and I'll try and stop it crashing (I wont say fix as I don't know your board...)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2544 on: Tue, 08 October 2024, 18:15:34 »
Hey guys, I know this is a bit of a necro, but looking for a bit of help.  Trying to program a JD40, green PCB, have had it for years now.  But the mods are staying pressed.  They just tap.  Any thoughts?  My GH36 programed just fine with it though.
