Author Topic: Need Help Finding This Keycap set  (Read 2598 times)
Offline Jpw926
« on: Thu, 21 November 2013, 00:23:59 »
Hi, i have been trying to decide what keycaps to get for when i get my first mechanical keyboard. I would like to have a set like http://i.imgur.com/FFSW4UY.jpg
I was hoping someone could help me figure out if these are pbt and where i might be able to purchase them. Also will these keycaps fit any mechanical keyboard or will they only fit Filco? Thanks.
Also if you have an opinion on a 180$ filco brown switch vs a 89$ Cm storm quickfire rapid brown switch, it would be much appreciated.
Offline PointyFox
Re: Need Help Finding This Keycap set
« Reply #1 on: Thu, 21 November 2013, 00:32:11 »
Those particular caps will fit any ANSI layout TKL or smaller board.  Also Filco and QFR are virtually identical.
« Reply #2 on: Thu, 21 November 2013, 03:41:00 »
I have two QF (one QFR one QFS), both are fine, solid, reliable boards.
Filco might have a slight edge, but you pay a lot more for basically the same keyboard.
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Thu, 21 November 2013, 04:23:36 »
WASDkeyboards lets you customize your own set of caps
