Author Topic: Picked up an M15 - Some questions..  (Read 3910 times)
Offline Michael
  • Formerly Bro Caps
« on: Thu, 21 November 2013, 08:59:49 »
So I grabbed an M15, and was wondering - does it use the same caps as regular moldel M's? I guess I mean; could you use the same caps as Model M's?
I am simply assuming the M15 caps are dye subbed PBT (minus the space bar, most likely).
Any thoughts on day to day use? How do you like it, and how long did it take you to adapt to the layout?
Much thanks, in advance.
« Last Edit: Thu, 21 November 2013, 09:18:03 by Bro Caps »
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
Re: Picked up an M15
« Reply #1 on: Thu, 21 November 2013, 09:02:45 »
afaik they have the same stem, but the keys are different shaped then the ones from a normal Model M. But I know it only from pics, never had one.
And they should be dye-sub pbt
  • Live long and prosper
« Reply #2 on: Thu, 21 November 2013, 09:04:34 »
I believe they do not use the same stems as regular Model Ms, but rather the one-piece keys used in the Model M2s.
tp thread is tp thread
Offline vivalarevolución
Re: Picked up an M15 - Some questions..
« Reply #3 on: Thu, 21 November 2013, 10:38:23 »
From pictures, it looks like the keycaps are differest profiles, while a typical Model M are all the same profile.  Considering the M15 does not have a curved backplate, that makes sense.
Offline BlueBär
« Reply #4 on: Thu, 21 November 2013, 10:42:43 »
The M15 should use the same caps as the Model M2. Here's an excerpt from the M2 article on the DT wiki:
The keycaps were of a different, incompatible type to the regular Model M ones. They were lower profile, and had a shorter and narrower stem. They were still made of PBT and still used dye sublimation printing.
Edit: Here's something from the M15 article as well:
The M15 is based upon the chassis of the Model M2 keyboard, and uses the same lower profile style of keycaps that are incompatible with those on a standard Model M keyboard
« Last Edit: Thu, 21 November 2013, 10:47:01 by BlueBär »
Offline Michael
  • Formerly Bro Caps
« Reply #5 on: Fri, 22 November 2013, 01:18:53 »
Thanks for the info. I seen some pics of the M15 caps, they definitely will not work on a standard M.
« Reply #6 on: Fri, 22 November 2013, 11:08:38 »
Did you pick up the one that just sold on Ebay?  With the cracked ball joint?
Offline Michael
  • Formerly Bro Caps
« Reply #7 on: Fri, 22 November 2013, 11:12:49 »
Yep
Offline Dubsgalore
« Reply #8 on: Fri, 22 November 2013, 11:38:03 »
Congrats Bro! I wanna see pics when you get it  :cool:
Offline Michael
  • Formerly Bro Caps
« Reply #9 on: Fri, 22 November 2013, 13:21:23 »
Congrats Bro! I wanna see pics when you get it  8)
Thanks bro. I will fo sho take some pix. Now I just need to find its long lost number pad mate
