Author Topic: Poker 2 - win led  (Read 2012 times)
Offline Cottonsox
Poker 2 - win led
« on: Thu, 21 November 2013, 15:58:26 »
Not sure if my newly aquired master solder skills (read first time ever) have screwed my pcb.
I tried using fn + shift to turn it on( I think that is correct... checked the manual) and this did not work.
The solder joints look ok, but when I was removing the exisiting led to change the color. I may have dmgd the pxb.
Is there a way I can check or/and is there a way to turn on the led I missed for poker 2.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
Re: Poker 2 - win led
« Reply #1 on: Thu, 21 November 2013, 16:00:20 »
fn + v sir
Offline Cottonsox
« Reply #2 on: Thu, 21 November 2013, 16:02:24 »
I have used that for all led, and the ones I have placed work except thw win key led. Manual said fn v was all bit win led.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #3 on: Thu, 21 November 2013, 16:04:44 »
Sorry, that's fn + z.
Misread lol.
Offline Cottonsox
« Reply #4 on: Thu, 21 November 2013, 16:12:20 »
I am thinking I might have damaged it, pretty sure I tried that already. But will givw it a go qhen I get back home.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #5 on: Fri, 22 November 2013, 08:41:25 »
any luck ?
Offline Cottonsox
« Reply #6 on: Fri, 22 November 2013, 08:59:43 »
Nope, I will try resoldering it at some point.
The key is functioning just the led. I did test each led before I put them in, so I think I have dmg the pcb.
Offline BlueBär
« Reply #7 on: Fri, 22 November 2013, 09:00:49 »
Can you post pictures of the PCB? If it is damaged the damage should be visible. Also, could it be that you put it in the wrong way?
Offline Cottonsox
« Reply #8 on: Fri, 22 November 2013, 09:05:06 »
I can say for sure I put it in the correct way, as I did them all at once along each row checkimg before I soldered. I will double check this when I get the time.
The pcb looks slightly damaged, was hoping it was not fatal.  But lt just may have been for that led.
I may not take it out until I get my new case from nubbinator,  so 2-4 weeks.
