Author Topic: HHKB O-ring mod woes.  (Read 2650 times)
Offline spammy1982
« on: Thu, 21 November 2013, 21:57:43 »
Howdy,
I have a HHKB pro2 and I'm almost finished with the o-ring silencing mod (50A durometer) but having trouble keeping the domes in place while I'm closing her up.  I'm tempted to tack them down with a bit of super glue.  Any guidance would be greatly appreciated.
~Sam
Re: HHKB O-ring mod woes.
« Reply #1 on: Thu, 21 November 2013, 21:59:49 »
You put orings on a hhkb?
« Reply #2 on: Thu, 21 November 2013, 22:13:08 »
Ive heard of landing pads, punched rubber, and dental bands, but i thought orings didnt fit?  Probably why theyre not staying..
Offline Michael
  • Formerly Bro Caps
« Reply #3 on: Thu, 21 November 2013, 22:17:31 »
I do believe he means dental bands.
The easiest way to do this, is to place the rubber cups in the face plate and hold the face plate upside down. They stay in place pretty well while you bolt up the bottom to the top.
So it should look like this as you are assembling it
« Last Edit: Thu, 21 November 2013, 22:21:05 by Bro Caps »
Offline jinxedx84
« Reply #4 on: Thu, 21 November 2013, 22:18:27 »
i dunno he specifically said "50a o rings"........
-filco TLK MX Blue & IMSTO thick blank blue keycaps
- White Poker II MX Blue
Offline spammy1982
« Reply #5 on: Thu, 21 November 2013, 22:22:29 »
it's the dental band mod and I'm happy with the feel and sound of 99% of the keys.  I'm just having trouble closing up
Offline spammy1982
« Reply #6 on: Thu, 21 November 2013, 22:24:55 »
Thanks Bro!  I was doing it upside down.
« Reply #7 on: Thu, 21 November 2013, 22:26:15 »
cool good to know for when i do mine tomorrow :D Thanks!
Offline spammy1982
« Reply #8 on: Thu, 21 November 2013, 22:31:54 »
I used- Bun-N O-Ring, 50A Durometer round black 3/16" ID, 5/16" OD, 1/16" width,  bag of 100 I got on Amazon.
Offline terran5992
  • One With The Cup Rubber
« Reply #9 on: Thu, 21 November 2013, 23:01:06 »
Do those even fit in the topre stem?
« Reply #10 on: Fri, 22 November 2013, 06:28:19 »
You should post some pics of those on the topre stems.
Most people who say dental band mod, literally use dental bands not o-rings. But I'm interested to see how they work out for you.
Offline theMANtonio
  • Go Hawks
« Reply #11 on: Fri, 22 November 2013, 10:44:55 »
The o-rings you specified would work perfectly on a Cherry MX board. For the Topre, I would recommend these: 3/16" 2.5 Oz. Dental Bands: http://www.amazon.com/gp/product/B00DB6OERK
Also, when closing the case on the HHKB, make sure the metal piece that protects the ribbon cable is not towards the bottom. It needs to be pushed back up to the middle before closing the case.
