Author Topic: LZ Mx mini under OS X  (Read 1367 times)
Offline Batmann
« on: Fri, 22 November 2013, 06:09:11 »
Hi guys,
I tried to use my LZ Mx mini on my macbook and it's acting weird.
Num lock is impossible to turn off and if I type at my usual pace (around 40 wpm) it will spam way more character than intended (most of them will be tripled or doubled)
Is this a known issue and is there any workaround?
Offline terran5992
  • One With The Cup Rubber
Re: LZ Mx mini under OS X
« Reply #1 on: Fri, 22 November 2013, 07:48:44 »
Hi guys,
Is it possible you are double tapping the key? If not it may be a problem with the switch or pcb
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #2 on: Fri, 22 November 2013, 07:50:58 »
I don't have either LZ Mx mini and/or Mac but I found this program which might help with your issue: http://www.denvog.com/app/numlock/
If you have spare machines and/or spare keyboards I would try and see whether:
  • Mac would turn the numlock on by default when the keyboard is plugged in.
  • The numlock can later be turned on/off on the fly when one presses numlock and/or via Fn function. Usually compact keyboards have numlock features enabled via Fn keys for instance.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Offline Batmann
« Reply #3 on: Sat, 23 November 2013, 10:49:56 »
Ok thanks for the input, not sure that's gonna fix my pb but it's worth checking
Offline MJ45
  • HHKB Pro
« Reply #4 on: Sat, 23 November 2013, 11:22:50 »
On a Mac there is no num lock function it would be F14. In the system preferences-keyboard- use the keyboard viewer to see what the keys register, it might give you an idea of whats going on.
