Author Topic: Making custom stems  (Read 2999 times)
Offline Wildcard
  • When caffeine isn't enough
Making custom stems
« on: Sun, 24 November 2013, 23:43:39 »
I've been slowly designing a custom MX stem that fits inside a shell type key cap cover (IBM caps are the perfect example).
I was originally looking to mold these out of some type of plastic, but I know the cost for the mold will probably be pretty high.  My other options are 3D printing or possibly making a 2 part silicone mold and using some type of epoxy, however I wonder how well this will work with such a small part.  Basically the final product will look like a small cuboid with an MX stem protruding out one side. You can insert it into a shell key cap cover with a dab of glue to make it permanent.
Can anyone suggest a good method to make these?
Offline Wildcard
Re: Making custom stems
« Reply #1 on: Sun, 24 November 2013, 23:58:42 »
After doing some digging I also found that that binge and photekq are also working on creating custom stems here, except I'm custom making it to replace an existing stem to fit a key cap for a much older keyboard.
I'll be closely following this thread for ideas on how to properly mold perhaps. This stem is very detailed towards the base. Hopefully I can make a working prototype.
You're gonna love this :)
« Last Edit: Mon, 25 November 2013, 00:12:55 by Wildcard »
« Reply #2 on: Mon, 25 November 2013, 17:15:48 »
I think that Mr Interface also has a project going on to make Cherry MX-compatible key stems that take IBM keycaps.
Offline Wildcard
« Reply #3 on: Mon, 25 November 2013, 20:25:03 »
It seems like a really good idea to bring life to these old key caps.
I guess I should try to finish my prototype and go the epoxy route.
« Last Edit: Mon, 25 November 2013, 21:49:19 by Wildcard »
