Author Topic: Tipro?  (Read 3037 times)
Offline Pacifist
  • on hiatus
Tipro?
« on: Tue, 26 November 2013, 00:29:05 »
Offline terran5992
  • One With The Cup Rubber
Re: Tipro?
« Reply #1 on: Tue, 26 November 2013, 00:34:40 »
You looking for a number pad?
Theres always the kpad, topre 23u, and the leopold one from elite keyboards
Offline Sniping
Re: Tipro?
« Reply #2 on: Tue, 26 November 2013, 00:39:33 »
Value of the 23U shouldn't be anything short of $200 at the moment. Countless number of people in classified that want a 23U.
Offline Pacifist
  • on hiatus
Re: Tipro?
« Reply #3 on: Tue, 26 November 2013, 00:44:11 »
Tipro is a number pad and it has a LOT of programmable keys
Re: Tipro?
« Reply #4 on: Tue, 26 November 2013, 00:46:45 »
Funny thing is just the other day one sold for $100  ::)
OP just get this and wire it with a teensy and build/find a case for it
http://www.ebay.com/itm/1-pc-White-Keyboard-5x5-keys-5-keys-Metal-Panel/130541363513
« Last Edit: Tue, 26 November 2013, 00:50:29 by SpAmRaY »
Offline CeeSA
Re: Tipro?
« Reply #5 on: Tue, 26 November 2013, 07:05:27 »
I love Tipro keyboards. So many modules and layouts. Programmability in 4 layes is very nice. Good Cherry MB Blacks.
1st link: looks like the Board has already a controller build in (pics of the PS/2 connecter a very dark, but I think there is one). So no need of a teensy.
2nd link: perfect for your personal Matrix Layout
3rd link: yes the same, the cardreader could be easily detached. Here you could see the built in controller for shure.
Some hints:
Software from Tipro works not at Win 64Bit over PS/2.
And you only have 2KRO. But I also use one modul for gaming without issue for me.
DIY Tipro Cabe: http://deskthority.net/wiki/Tipro_Cable
« Last Edit: Tue, 26 November 2013, 07:07:15 by CeeSA »
Offline Pacifist
  • on hiatus
Re: Tipro?
« Reply #6 on: Wed, 27 November 2013, 11:17:15 »
can you mod that to cherry switches?
Re: Tipro?
« Reply #7 on: Wed, 27 November 2013, 11:31:02 »
Its just a plate, Cherry switches fit in it.
Offline davkol
  •  Post Editing Timeout
Re: Tipro?
« Reply #8 on: Wed, 27 November 2013, 14:21:39 »
You need to hardwire them then, don't you?
Re: Tipro?
« Reply #9 on: Wed, 27 November 2013, 14:26:18 »
Yep
