Author Topic: More info on this Cherry keyboard?  (Read 3662 times)
Offline colinstu
« on: Mon, 19 January 2009, 05:17:02 »
G80-3000LQMUS
Best picture I could take of the switch... White Cherry switches
What exactly is this kind of switch like? The feel of the whole thing doesn't seem much different then a membrane keyboard, but there is a certain feel that makes it 100% better then one.
May 11th 1989, IBM Model M 1391401
Offline lam47
« Reply #1 on: Mon, 19 January 2009, 05:49:39 »
it should feel 100% different to a membrane.
The clear Cherries should be tactile clicky switches and be a million miles away from any membrane board.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline sandy55
« Reply #2 on: Mon, 19 January 2009, 06:10:05 »
lam, It's Soft Contact, in cherry language.
Offline lam47
« Reply #3 on: Mon, 19 January 2009, 06:41:02 »
Oh ball is it?
They look like proper switches to me.
If its one of those horrible ftsc ones then eww. My apologise. Its worse than a membrane.
I didnt sleep so I might be talking rubbish but wise is the star captain in a flock of rubber geese.
Offline sandy55
« Reply #4 on: Mon, 19 January 2009, 06:42:14 »
Quote from: sandy55;18681
Wow, big mistake.    "Soft Tactile"  actually.
Offline lowpoly
« Reply #5 on: Mon, 19 January 2009, 06:48:26 »
G80 Cherry MX switch
3000 the big standard case
L lasered keycaps
Q soft tactile
M ps/2 connector
US ANSI layout with horizontal enter
The soft tactile should have a stronger spring than the brown which is 'soft tactile ergonomic'. I'm still puzzeled when it comes to white and clear MXs.
Offline sandy55
« Reply #6 on: Mon, 19 January 2009, 06:49:55 »
Well, It's a proper MX mechanical switch with stiff spring like MX/blacks, bit stronger tactile feel than MX/browns.  Worth than membrane. But MX/white is not my choice.
Anyway , very very sorry for confusion.
sandy, the fox
Offline colinstu
« Reply #7 on: Mon, 19 January 2009, 07:17:37 »
This keyboard is a 100x nicer then a membrane, but no definite click sound, etc like my Model M :)
Offline xyzzy
« Reply #8 on: Mon, 19 January 2009, 07:55:50 »
If you press the key very slowly, you should be able to feel a "bump" about 1/4 or 1/3 on the way down.
As sandy said, they're basically Cherry brown switches (soft tactile feedback with NO click sound) with stronger springs (like Cherry blacks).
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
