Author Topic: CM Storm QF Pro Custom Keycaps (Cherry MX Browns)  (Read 2152 times)
Offline zuttypiggy
« on: Tue, 26 November 2013, 12:02:57 »
All,
Thanks in advance. My Spacebar on the Storm pro broke (another story) and i'm looking to take the opportunity to replace the spacebar but maybe some other caps. I've heard that the spacebar on this thing is a little "abnormal" size wise so I was wondering if anyone had any luck replacing Keycaps on the thing and where they got them from.
Thanks again
Offline terran5992
  • One With The Cup Rubber
Re: CM Storm QF Pro Custom Keycaps (Cherry MX Browns)
« Reply #1 on: Tue, 26 November 2013, 19:39:41 »
Its a 6x Spacebar
Offline legodt
« Reply #2 on: Tue, 26 November 2013, 20:33:21 »
Wait, really? Are you sure it is just a standard 6x?
Offline terran5992
« Reply #3 on: Wed, 27 November 2013, 00:37:18 »
Im pretty sure
