Author Topic: Can SMK mounted Alps be transported into other Non-SMK Alps boards?  (Read 1859 times)
Offline dante
According to this, SMK mounted Alps cannot be transferred to another board due to pin layout.  Is this correct?
The keycaps are compatible with Alps CM but the switch has a different mounting hole and pin layout. A coiled spring provides most of the resistance, and there are two leaf springs for contact and click/tactility respectively.
http://deskthority.net/wiki/SMK_Alps_mount
Re: Can SMK mounted Alps be transported into other Non-SMK Alps boards?
« Reply #1 on: Wed, 27 November 2013, 14:18:00 »
If you are referring to "blue Monterey" switches, tough luck.
As I understand it (I have never even tried it) the pin layout makes them incompatible with anything.
Too bad! If you figure out a way, let us know - I would gladly strip my Chicony 5181 and put them somewhere else.
- D Trump 2026-10-24
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #2 on: Wed, 27 November 2013, 19:04:19 »
"SMK Alps mount" is possibly a hard name to parse; at the moment, we have no idea what SMK called them.
They're SMK switches that take Alps keycaps — I started referring to them as SMK Second Generation, and this comprises "Montereys" (the blue ones that take Alps keycaps), "white Montereys", the ones that take Cherry keycaps, and the ones that take SMK's custom keycap mount. None of these switches are interchangeable with any other brands. Strictly speaking, there seems to be a gap between the most-recently-seen SMK linears (last seen around 1984) and "second-generation" switches (first seen around 1986), but no other SMK switches appear to have turned up. I would be really interested to know what was sold in that gap. The US patent for "second-generation" switches was filed in 1987.
I don't class them as Alps clones for a second reason: the internal mechanism is based on their (SMK's) old linear switches (the first known SMK switches to date), where a ramp on the slider levers the movable contact away from the static contact. The lintel contact was replaced with a piece of bent wire, but the idea is the same. It's got far more in common with Cherry M7 than Alps designs.
(So far, HaaTa hasn't turned up any 1970s SMK switches ... while Cherry's switches (M6/M7) go back to the early 70s! We're also unclear on when Futaba's switches first appeared.)
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Wed, 27 November 2013, 19:27:24 »
i was going to say ask daniel............, but looks like he already responded to ur post
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
