Author Topic: Sticky Enter  (Read 2608 times)
Offline terran5992
  • One With The Cup Rubber
Sticky Enter
« on: Wed, 27 November 2013, 03:21:42 »
The key depresses halfway and stays there. Any thing i can do to fix this problem? Its not happening to  the other stabalized keys.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Sticky Enter
« Reply #1 on: Wed, 27 November 2013, 03:26:21 »
You haven't clarified whether you're talking about a Cherry MX keyboard or a Topre keyboard.
Offline terran5992
Re: Sticky Enter
« Reply #2 on: Wed, 27 November 2013, 03:36:29 »
Cherry mx with Cherry Stabs.
Srry
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
Re: Sticky Enter
« Reply #3 on: Wed, 27 November 2013, 03:42:32 »
Did you spill juice on it?
Having a bad day?
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Sticky Enter
« Reply #4 on: Wed, 27 November 2013, 03:44:38 »
Srry
I think, either your switch is messed up (what switch type are you using), or your stabilizers are pinched/gathered together. Try stretching out the stabilizers so the top opening isn't leaning inwards.
Re: Sticky Enter
« Reply #5 on: Wed, 27 November 2013, 03:52:19 »
Or the stems under the key are not 100% straight - this is occasionally an issue with Cherry stabs as there is little to no room for misalignment.
Can you try a different Enter key on this board?
Can you try the sticky Enter on a different keyboard (if possible one with Cherry and one with Costar stabilisers)?
Offline terran5992
Re: Sticky Enter
« Reply #6 on: Wed, 27 November 2013, 04:16:45 »
Its an issue with the stabalizer. Ive tried another enter key i had and it also got stuck
Offline terran5992
Re: Sticky Enter
« Reply #7 on: Wed, 27 November 2013, 04:19:27 »
Fixed the problem
The key is about 3/4 the way inside the switch. After that no more problems
Offline Moosecraft
  • HHKB Pro
Re: Sticky Enter
« Reply #8 on: Wed, 27 November 2013, 05:18:59 »
You could also lube the stabilizer.
Offline terran5992
Re: Sticky Enter
« Reply #9 on: Thu, 28 November 2013, 07:57:29 »
It is already lubed
