Author Topic: HHKB Pro 2 Question!  (Read 20599 times)
Offline kernelfodder
Re: HHKB Pro 2 Question!
« Reply #50 on: Fri, 29 November 2013, 04:07:21 »
I've heard some say typing on 55g makes them tired. Whats the appeal of getting 55g's?
I like MX blacks and greens - 60g?
reds and blues just feel too light for me now.
Topre is inbetween.
Is your HHKB 55g?
45g HHKB Pro 2.
Would you upgrade to 55g for 260 bucks?
I would seriously consider it.  HHKB is great feeling of oneness with cup rubber, but every now and again I find myself accidentally resting my finger a little bit too hard on a key and getting a row of characters across the screen.
Would I be able to do the 55g mod to the HHKB without much modding experience? I still cant find much of a guide. The link posted above doesn't really help as it wasn't too clear to me on what to actually do.
Filco MJ2 MX Brown/ Filco MJ2 Ninja MX Blue/ Realforce 87U 45g/ HHKB Pro 2 Type-S 55g/ Poker II MX Brown/ Poker II MX Blue
« Reply #51 on: Fri, 29 November 2013, 04:12:07 »
Basically you take them apart and swap domes. Nothing to it really.
But everyone is different.
Also here is a link to a thread and it has more links in it.
http://geekhack.org/index.php?topic=45098.0
« Last Edit: Fri, 29 November 2013, 04:15:39 by SpAmRaY »
« Reply #52 on: Fri, 29 November 2013, 04:19:05 »
I wouldn't want to do that to my HHKB.  Apart from not having time to do it properly, I wouldn't want to run the risk of damaging an expensive keyboard.
Offline atlas3686
  • HHKB Elite
« Reply #53 on: Fri, 29 November 2013, 04:27:20 »
I feel the same way, while a 55g type-s would be great, I just couldn't risk damaging the type-s.
« Reply #54 on: Fri, 29 November 2013, 04:31:57 »
Would it be that easy to damage? Looking at the great posts provided by Spamray, it seems quite straightforward now. Or am I getting it wrong?
Btw, where does everyone get those cool topre caps?
« Reply #55 on: Fri, 29 November 2013, 04:39:17 »
You just have to be careful when disassembling/assembling etc.
And there can be some trial and error getting springs and domes all in place properly.
Offline Belfong
« Reply #56 on: Fri, 29 November 2013, 09:09:54 »
Quick question - changing caps should be easier than silencing right? Or do I have to juggle with springs too when changing key caps?
I now have another opportunity - my brother in law is going to Japan for a couple of days and I am thinking of asking him to buy the white/grey key caps. I have a black on black HHKB and my dilemma is whether I should buy white/grey blanks or white/grey with legends. It cost $45 each, much cheaper than EK and should I just bite the bullet and get both? Ahh.. decisions! I doubt after this anyone I know would go Japan again for years!
Offline Sniping
« Reply #57 on: Fri, 29 November 2013, 09:37:16 »
Topre is inbetween.
Is your HHKB 55g?
45g HHKB Pro 2.
It doesn't actually cost $260 because you can swap the domes and then sell the Realforce as a 45g board.
« Reply #58 on: Fri, 29 November 2013, 09:48:12 »
Changing caps doesn't involve springs.
Offline Belfong
« Reply #59 on: Fri, 29 November 2013, 10:00:29 »
Thanks SpAMRaY!!
Offline MJ45
  • HHKB Pro
« Reply #60 on: Fri, 29 November 2013, 12:45:50 »
There is one spring under the spacebar on Topre keyboards.
« Reply #61 on: Fri, 29 November 2013, 12:54:02 »
Forgot about that one! I always leave it out.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #62 on: Fri, 29 November 2013, 12:59:29 »
Define "cool". Those fancy skull caps or caps with animal on it are clack keys and binge caps respectively. There are a few other companies that prints fancy stuff on the key caps that they sell but they are usually restricted to one form of mechanical switch (usually Cherry MX).
Topre boards have very little customisation available as of writing. Apart from clack factory or binge caps, the rest are vastly swapping in between blanks, legended keys with other languages printed on it, or even coloured key caps (in which you only have like five or six to choose from).
Oh right I forgot to include some links:
Former link could do some updating, there's no listing for bingecaps for instance.
« Last Edit: Fri, 29 November 2013, 13:07:04 by tuxsavvy »
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
« Reply #63 on: Fri, 29 November 2013, 13:17:09 »
^^Binge has a website.
