Author Topic: HHKB Pro 2 Question!  (Read 20598 times)
Offline kernelfodder
« on: Wed, 27 November 2013, 23:37:10 »
Hi There!
 I'm seriously considering getting an HHKB Pro 2. But unfortunately my choice has come down to the aesthetics of the keyboard; typical isn't it?
I was wondering if any HHKB owners out there can shed some light on a few subjects. And if anyone in general can field their opinions about it. Anything at all, maybe I'm being a tad too picky and should go ahead and just flip a coin.
Printed or Non-Printed?
I'm fairly set on getting a Non-Printed one, as I'm quite familiar with the layout and I currently don't have a Non-Printed board. Seems fitting that the non-printed board would be the only Topre board, streetcred +1.
However if anyone has anything to say on this I would very much love to hear it.
White or Black?
I can't really decide on this. I like the look of both. I feel like the white harkens back to the era of the *nix terminals, and black keyboards are everywhere these days. But the black just has so much cybercredsz, how else will I increase my epeen?
Type-S?
I'm pretty much set on not getting the Type-S, mainly for the fact that its 200 dollars more. And from what I can tell, it doesn't get that much more quiet. Any differing opinions?
I know there will be a lot of you that might say "Just decide for yourself" and things like that, honestly I agree and I will eventually. But for a keyboard like this, I personally like to get all points of view. I would appreciate the input very much, and I hope that the community and any future HHKBp2 buyers might benefit from the discussion that comes out of this.
Cheers!
Filco MJ2 MX Brown/ Filco MJ2 Ninja MX Blue/ Realforce 87U 45g/ HHKB Pro 2 Type-S 55g/ Poker II MX Brown/ Poker II MX Blue
Re: HHKB Pro 2 Question!
« Reply #1 on: Wed, 27 November 2013, 23:42:03 »
So here is what you do.
Buy a HHKB pro 2 black with printed caps, buy a set of blank caps for the white board, buy a realforce 55g, also buy some lube and dental bands.
You mod the HHKB with the 55g domes from the realforce and the dental bands and lube.
Try out the caps see if they work for you being blank or not.
Sell whatever is leftover.
« Reply #2 on: Wed, 27 November 2013, 23:45:52 »
I would love to do that. Unfortunately I live in SEA and I have a deadline to order the HHKB as its being couriered over here by a friend.
Interesting idea though.
« Reply #3 on: Wed, 27 November 2013, 23:51:01 »
Welcome to Geekhack!
Legends or blank is really up to you.  HHKB layout is different to the conventional fullsize or even TKL layout, so most people usually start with printed keycaps and upgrade (UPgrade ha!) to blanks when they bacome familiar with the layout.  If you are already familiar with the layout, there is no reason why you should not start with blanks.  I am happy with my printed keycaps, but then I switch between 3 or 4 keyboards on a daily basis.
I like white - a nice classic look.  Many prefer black.  Some mix and match.  You can even (try to) get some coloured RealForce keycap sets and mix and match those too!
dustinhxc silenced his own HHKB recently, have a look here - very informative series of pictures.
I am happy with mine as it is.
HHKB Hapster :)
« Reply #4 on: Thu, 28 November 2013, 00:16:35 »
Thanks Rowdy!
Very Helpful post!
When I said I was familiar with the layout I meant just the 60%'s. I realize that the HHKB key layout is very different. Do you think its worth grabbing printed keys just to learn? They are about 80 bucks. Or is it easy to learn with a reference every one in a while?
Offline PointyFox
« Reply #5 on: Thu, 28 November 2013, 00:23:29 »
Thanks Rowdy!
Very Helpful post!
Print a picture of it with the printed keys and keep it by your keyboard until you learn.  Much cheaper.
« Reply #6 on: Thu, 28 November 2013, 00:29:46 »
Agreed.
Offline kelske
  • The North Borders
« Reply #7 on: Thu, 28 November 2013, 01:21:21 »
Personally I'm quite a fan of legends... and legends don't get much more delicious than the ones on the HHKB keys!
I was considering getting the black one then chucking white keycaps on it, but now that I've got the white version I think i prefer it.
As for Type-S, I got it through a friend in Japan. That $140 price difference is cut in half when buying from Amazon.co.jp :thumb:
« Reply #8 on: Thu, 28 November 2013, 01:59:46 »
Is the sound difference really that noticeable?
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #9 on: Thu, 28 November 2013, 02:12:32 »
Hi There!
White or Black?
Type-S?
Cheers!
As said before by rowdy, printed key caps are mainly used by people who are familiar with the 60% layout. I have printed key caps on mine because mine is different, I am learning JIS layout and I am also somewhat fairly new to the 60% scene. Too bad in my case there are no unprinted key caps for my specific layout.
About colours, they say that the dust will be somewhat more visible on the black one. The white one however may get dirty over time (though not as quick as white ABS key caps seeing as how PFU chose to use PBT, the same more or less as with virtually every other Topre based keyboard out there). HHKB Pro2 black isn't exactly black it is more like gray. If you are going to choose that sort of colour you might also want to factor in that the legends on the keys may not be easily seen without a light at night. This is mainly because the legends are printed black, the same as with the white variant but it is probably more visible at night. If you are new to the 60% scene, it might actually be none the wiser to start with the white first if you prefer to sometimes work in the dark (I personally do at times).
To go with silenced or not depends on how comfortable one is with d-i-y silencing. Type-S indeed is more expensive than non Type-S but I wouldn't go as far as saying that it is $200 more unless you happen to live in places where customs tax are high. They are roughly around USD$2 (JPY¥182) for non printed HHKB Pro2 and about USD$70 (JPY¥7082) as of writing from amazon.co.jp (mostly Japanese, be warned):
Printed/legended key caps (first link is standard and the second is Type-S variant):
http://www.amazon.co.jp/PFU-Keyboard-Professional2-USB%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89-PD-KB400WN/dp/B000F1HWFU/
http://www.amazon.co.jp/PFU-Hacking-Keyboard-Professional2-%E7%99%BD%EF%BC%8F%E7%84%A1%E5%88%BB%E5%8D%B0%EF%BC%88%E8%8B%B1%E8%AA%9E%E9%85%8D%E5%88%97%EF%BC%89/dp/B008GXT6SK/
Blank/unprinted key caps (first link is standard and the second is Type-S variant):
http://www.amazon.co.jp/PFU-Keyboard-Professional2-USB%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89-PD-KB400W/dp/B000EXZ0V2
http://www.amazon.co.jp/PFU-Hacking-Keyboard-Professional2-%E7%99%BD%EF%BC%88%E8%8B%B1%E8%AA%9E%E9%85%8D%E5%88%97%EF%BC%89/dp/B008GXQWOG
amazon.co.jp seems to not have gray version of Pro2 Type-S as of writing. Also amazon.co.jp does not ship outside Japan, so you need to use a forwarding/proxy service (which will cost you extra for forwarding fees but the fees vary from forwarder/proxy to forwarder/proxy) on top of paying fees for shipping the product to you. This may work out cheaper than buying it from certain places but you may forfeit 1 year warranty if for example you bought the keyboard not from elitekeyboards.com but direct from Japan.
Aurally, I guess the Type-S does not have that slightly harsher sound when maybe the slider goes down and up. Also because it has a foam in between each of the sliders on the Type-S when the key is released it does not make that "thock" sound quite loud. Notably because it has something in between to prevent the sound of plastic bumping on plastic that loud.
The slider/plunger design maybe quite different between a standard and a proper Type-S for instance the base of the slider is not as square on the standard one, it is more kinda like oval shaped on Type-S. The latches also on the normal one does not stick out as much on the standard one as it does for the Type-S. OO2 gave me part of the information I said about the differences with the design. I personally do not have the standard variant but I have seen a photo of where the slider is more smooth on the Type-S as opposed to normal.
I guess the slight differences in design between the two does not really make all that much difference. In other words, if I were to take the factory fitted foam off my HHKB it should sound as loud as a regular HHKB Pro would in theory. I guess having a smoother walls on the slider may prevent the wear and tear on the foam based silencing.
The price of the Type-S is somewhat unjustifiable I guess especially if one is willing to take their HHKB apart and fit their own silencers, etc. It has been done before as rowdy pointed out a link, there has been already a fair few people that have silenced their own HHKB via either dental band hack or foam hack. Foam hack requires a bit more work than dental band hack imo.
From my own personal point of view with my Type-S is that it sounds almost like as if it is some sort of a cheap membrane based keyboard. In other words, I am not able to hear the "thock" sound at all unless if say for instance I put my ear on the keyboard and try to hear the sound as I release the keys. Though I have yet to take the foam out and to try and see if the "thock" sound would be more pronounced than before
If by any means you prefer a cheaper alternative than for instance sourcing it from elitekeyboards, here is a good link describing one how to source HHKB (and other goods from Japan) by going through a forwarding/proxy service: [Guide] Bought my HHKB Pro 2 from amazon.co.jp : MechanicalKeyboards
Also I believe (and from some people I have also heard from recommending) tenso.com is probably the best Japanese forwarding service out there.
Last but not least I want to make a note here that if you (by any means) sourced your HHKB from Japan. Do be aware that you do not have 1 year manufacturer's warranty. Instead if you have any issues with your HHKB the only way is to harrass your seller. I have noticed that my HHKB has an empty warranty "sheet". There was nothing filled out under the shop name and address nor was the purchasing date was noted. The said warranty sheet printed most of its terms and conditions in Japanese with the exception of one notable rule: "3.本書は日本国内においてのみ有効です。This warranty is valid only in Japan." This is written as it is on the warranty sheet. It is the only rule that is written in both Japanese and English. So here is basically your caveat emptor so to speak.
I believe that the seller bought the keyboard straight from PFU directly (through their website) and simply just forwarded the parcel onto me. My HHKB (because it is JP variant) means that I must go through some proxy/forwarding service as elitekeyboards does not offer this sort of keyboard. I do not know how elitekeyboards work but supposedly if one has issues with their HHKB they can send their keyboards back for replacement I guess however in my case I have to go nag my seller if there were issues with my HHKB.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
« Reply #10 on: Thu, 28 November 2013, 02:20:38 »
the DIFFERENCE is noticeable..
but ask yourself..  if you only ever had that one board.. how would you ever hear the "difference"...
secondly_   it's still very loud compared to a regular dome board..
Offline Sniping
« Reply #11 on: Thu, 28 November 2013, 02:28:34 »
The difference is quite noticeable and I think you should just go with a blank white HHKB Type-S...Getting the normal one makes you want to do a silencing mod, then you discover that you should've just gotten the HHKB Type-S to begin with.
Offline theMANtonio
  • Go Hawks
« Reply #12 on: Thu, 28 November 2013, 03:05:41 »
Except dental bands cost $5+an hour or so of work compared to an extra $140 for the Type-S ($260 vs $400 based off EK prices). Huge difference IMO.
« Reply #13 on: Thu, 28 November 2013, 03:09:08 »
FWIW here's mine:
46070-0
Offline Emospence
« Reply #14 on: Thu, 28 November 2013, 04:00:27 »
1. Personal preference. Printed for me, more or less know where buttons are but like the assurance
2. Personal preference. White for me, the font is clearer
3. Personal preference. For me, the non Type-S is already so quiet I don't want it any quieter. If you think differently, try the dental thingy mod
HHKB keys really feel awesome, grew on me over some weeks.. But missing my arrows and backspace+del, so ordered 2 87U 55gs :p
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline Belfong
« Reply #15 on: Thu, 28 November 2013, 04:24:26 »
I went with the black on black because I like how the white-grey caps looked on the black case, for the future when I want to change key caps.
I also went with the non-blank caps to get familiar with the layout, knowing full well when I changed to the white-grey caps, I will choose the blanks one.
As for Type-S or not, no idea. For the additional price, you might as well buy extra key caps. And to me, the thock sound is the signature of the HHKB. Why do you want to silence it?
Offline kfmfe04
« Reply #16 on: Thu, 28 November 2013, 04:48:38 »
I absolutely love the classic white with legend.
My only issue is, I am transitioning to Colemak and I can't swap around these sculpted keys.
Are there any keycap sets out there that look like the classic font that I can get in Colemak?
Since I am a touch-typist, I could still go for classic white with QWERTY layout, just for the looks, though (prolly what I'll do).
⌨White Blank HHKB P2 ⌨Filco TKL SA MXRed
Interests: ⌨AcidFire's Board ⌨Kinesis Advantage LF
Offline terran5992
  • One With The Cup Rubber
« Reply #17 on: Thu, 28 November 2013, 05:31:28 »
I might recommend a new user who dosent know the hhkb layout well to get a hhkb with printed keycaps
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #18 on: Thu, 28 November 2013, 05:41:27 »
I must say white caps are slightly nicer. First they're more readable if you're after legends, second they have a nicer slightly smoother texture.
Offline Sniping
« Reply #19 on: Thu, 28 November 2013, 09:31:06 »
The key travel is reduced quite a bit when you do the mod and isn't the same when you buy a Type-S where they use really thin rings and also have longer stems to account for the lost travel distance.
Offline theMANtonio
  • Go Hawks
« Reply #20 on: Thu, 28 November 2013, 11:12:11 »
Good point. I have noticed the travel change a bit.
As for my situation, I went with a black HHKB w/ printed black keys. I got used to the layout a bit and saved the HHKB layout picture on my desktop if I ever need to look up key location or function layer. Then I bought a set of blank white keys w/ blank red esc. Beautiful on a Black HHKB.
« Reply #21 on: Thu, 28 November 2013, 11:26:53 »
Myself, I like black case and type s only comes in white. I like white blanks. I like silenced. Solution: black with printed so you have a printed version, white blanks, dental bands, open the case up and put dental bands on the sliders. The perfect board!
Offline ctbear
« Reply #22 on: Thu, 28 November 2013, 13:06:04 »
I have a white non-printed. I have always like the clean look of otaku keyboards, and the two-tone caps really look better than the black ones imo.
Offline MJ45
  • HHKB Pro
« Reply #23 on: Thu, 28 November 2013, 13:21:50 »
Go with your instincts its your choice and have to type on it, do what is right for you!
Plan B what I would do;
I like black and white is nice but I fear a white case yellowing with age (its ABS)
Here is what you do.
Buy a HHKB black with printed caps.
Buy a HHKB Type S with blank or printed caps and a RF 87ub 55g and some lube. Mod the black HHKB with Type S plungers, 55g domes from the RF and lube it. Then you'll a have a Black HHKB 55g Type S done right and keep the caps you prefer.
Sell what's leftover easy peasy.
« Reply #24 on: Thu, 28 November 2013, 21:18:16 »
Do you have a picture of that?
« Reply #25 on: Thu, 28 November 2013, 21:21:07 »
Thats almost a $800 board.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #26 on: Thu, 28 November 2013, 21:34:30 »
Unless you plan to give away the leftovers for free, you still would be able to recouperate some costs. HHKB for instance hold their value fairly well on the resale market, so it is not like a complete write off.
Offline MJ45
  • HHKB Pro
« Reply #27 on: Thu, 28 November 2013, 21:44:52 »
Well yes but in the end after selling leftovers you would end up with a custom Black HHKB 55g Type S for about the same price as a reg White Type S. Still a lot of money $400 i sch.
« Reply #28 on: Thu, 28 November 2013, 22:32:00 »
Are you saying you wouldn't do it?
« Reply #29 on: Thu, 28 November 2013, 23:04:34 »
As someone who likes the sound of blues, would I like the sound of the type-s?
« Reply #30 on: Thu, 28 November 2013, 23:35:43 »
I thought the point of the type-s was to be silent....therefore no sound....
But topre doesn't sound anything like mx blues.
« Reply #31 on: Thu, 28 November 2013, 23:37:38 »
I understand that, but I'm getting the feeling that people think the HHKB is too loud in the first place. Does that have any merit?
« Reply #32 on: Thu, 28 November 2013, 23:41:09 »
It's not super loud or anything, at least not to be. I suppose it partly depends on your typing style.
But there is the topre 'thock' that you see mentioned, not sure how else to describe it.
There are some user videos posted around showing regular topre, modded topres and type-s's I believe.
Offline Emospence
« Reply #33 on: Thu, 28 November 2013, 23:42:05 »
Not to me, not at all. People are saying the upstroke sounds plasticy but I don't get that at all
« Reply #34 on: Thu, 28 November 2013, 23:53:22 »
That idea that MJ45 had :
 HHKB Black
 HHKB Type-S White
 RF87UB 55g
And taking the 55gs to the black hhkb base and the type-s plungers. That looks quite appealing, but I'm having a hard time justifying the 900$ initial purchase price.
Offline atlas3686
  • HHKB Elite
« Reply #35 on: Fri, 29 November 2013, 00:30:08 »
 HHKB Black
 HHKB Type-S White
 RF87UB 55g
Don't worry it's not just you having trouble justifying it. In fact I have never seen or heard of one that has actually been done. There are some guys with just the 55g in an HHKB.
« Reply #36 on: Fri, 29 November 2013, 00:53:35 »
 HHKB Black
 HHKB Type-S White
 RF87UB 55g
Pretty sure its been done.
« Reply #37 on: Fri, 29 November 2013, 00:59:41 »
I've heard some say typing on 55g makes them tired. Whats the appeal of getting 55g's?
« Reply #38 on: Fri, 29 November 2013, 01:05:09 »
Some of us just prefer heavier switches.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #39 on: Fri, 29 November 2013, 01:15:11 »
There is this post as well for instance: http://geekhack.org/index.php?topic=51615.msg1138025#msg1138025
« Reply #40 on: Fri, 29 November 2013, 01:57:10 »
Where can I find material on how to do the mods?
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #41 on: Fri, 29 November 2013, 02:03:51 »
Not sure on what you meant by material, but there is a guide for instance here: http://deskthority.net/workshop-f7/hhkp-pro-jp-variable-force-silencing-mods-t5196.html?hilit=silencing%20mod
« Reply #42 on: Fri, 29 November 2013, 02:06:07 »
There are a few threads on the forum. I'm on my phone or else I'd post links.
« Reply #43 on: Fri, 29 November 2013, 03:08:54 »
I like MX blacks and greens - 60g?
reds and blues just feel too light for me now.
Topre is inbetween.
« Reply #44 on: Fri, 29 November 2013, 03:23:11 »
Topre is inbetween.
Is your HHKB 55g?
« Reply #45 on: Fri, 29 November 2013, 03:27:32 »
Topre is inbetween.
Is your HHKB 55g?
45g HHKB Pro 2.
« Reply #46 on: Fri, 29 November 2013, 03:28:12 »
I'd very much appreciate the links spamray, I can't find the threads anywhere.
« Reply #47 on: Fri, 29 November 2013, 03:37:13 »
Topre is inbetween.
Is your HHKB 55g?
45g HHKB Pro 2.
Would you upgrade to 55g for 260 bucks?
Offline atlas3686
  • HHKB Elite
« Reply #48 on: Fri, 29 November 2013, 03:57:41 »
 HHKB Black
 HHKB Type-S White
 RF87UB 55g
Definitely! Someone out there must have the money and inclination :) Just wish PFU would do it for us.
« Reply #49 on: Fri, 29 November 2013, 04:03:08 »
Topre is inbetween.
Is your HHKB 55g?
45g HHKB Pro 2.
I would seriously consider it.  HHKB is great feeling of oneness with cup rubber, but every now and again I find myself accidentally resting my finger a little bit too hard on a key and getting a row of characters across the screen.
