Author Topic: The Ergopwn Xtreme 9000.... First Vertical Gaming Mouse Ever  (Read 30113 times)
« on: Wed, 27 July 2016, 09:09:27 »
As far as I know this is the first Vertical mouse ever with a pixart 3366 sensor..
After trying vertical, you really begin to see the tremendous flaw of turning one's wrist so deeply to hold a regular horizontal mouse..
I've been using this specific vertical mouse for 4 days (YEARS NOW) ,  and have come to the conclusion that, There is no going back..
Overall, I find that this shape is the most vertical and most tension relieving among the other vertical mice. (I've tried them ALL)
Since there are no commercially available vertical mouse with a good sensor,  it was necessary to splice..
Materials Required:
1____   23/24 awg solid copper wire.
2____   Twist ties to mount base to pcb
3____   USB 2.0 Hub (full speed), @ least 2 ports.....  $4 ebay
4____   Nanokk, Evoluent mouse Knockoff, (perfect shape clone)..... $20 ebay
5____   Logitech G303........ $24 amazon sale
6____   1 set of WMO Hyperglides.....
Make sure to Cover the Lens while you work on the mouse.. Don't wanna melt the lens via stray solder.
--- It's a very straight forward mod, snap hub in 2 pieces, hook up both mouse (internally) to the hub piece with the chip on it..  solder buttons to g303, keep wheel attached to nanokk..
159010-1
159012-2
159014-3
159016-4
159018-5
159020-6
The Lens is TAPED in this photo because during soldering, you want to make sure no stray solder pops and melt the lens..
Remove tape only during assembly, The lens is acrylic, easily scratched.
Imgur Backup photo vvvvv
Key Insight:
the Nanokk uses a mechanical wheel encoder, whereas the logitech uses an optical system.
This is the reason why you need a hub to preserve the wheel functionality.  This is essentially 2 mouse in 1.. running in parallel.
The reason there are so many extra cables in the later picture, is because all the buttons with the exception of the wheel-up, wheel-down, are wired to the G303.  The G303 has much lower click/button latency vs other mice..  You can skip this step to keep things more simple,  but then WHY DO IT, if you're not going to go all the way..
The mouse weighs 135 Grams in this configuration..  Can be lightened, by sacrificing wheel functionality..  dropping 2 extra pcbs.. (it won't be much lighter 10-15g)..
The USB pin out label on the Nanokk PCB has DM and DP flipped.. VCC and G is correct
Re: The Ergopwn Xtreme 9000.... First Vertical Gaming Mouse Ever
« Reply #1 on: Wed, 27 July 2016, 17:07:10 »
Evoluent is the worst conceivable vertical mouse configuration in the universe.
By its nature you must "pinch" it between thumb and fingers - there is no simple 1-finger tapping because "equal and opposite reaction" will cause it to move unless it is restrained by the thumb.
Neither vertical nor horizontal is best. The mouse should lean in at about 45 degrees so that the wrist is rolled over partially but gravity is still working in your favor.
I just wish that a decent left-hand vertical mouse existed.
"The Trump campaign announced in a letter that Republican candidates and committees are now expected to pay “a minimum of 5% of all fundraising solicitations to Trump National Committee JFC” for using his “name, image, and likeness in fundraising solicitations.”
“Any split that is higher than 5%,” the letter states, “will be seen favorably by the RNC and President Trump's campaign and is routinely reported to the highest levels of leadership within both organizations.”"
« Reply #2 on: Wed, 27 July 2016, 17:36:24 »
Evoluent is by far the best shape..
I can understand how a novice to ergonomics might not understand how to use one. .hahahaha
Very basically, you have to learn to lightly pinch the mouse between the thumb and pinky..
Ontop of that, Mouse height must be adjusted to BELOW elbow height..
There is an adjustment in TECHNIQUE, that comes with vertical mousing..
You can't expect all your old habits to work,  they don't..
Fohat's complaint is the same as those who are not using the ERGODOX properly
As for 45* mouse,  It does not solve the wrist angle problem whatsoever
The reason is,  If you tilt even 45degrees, you are STILL rotating inwards in order to click the button..
You're essentially pushing against the rotation in your wrist..
This rotational stress is responsible for the majority of forearm related RSI..
I think , the next step, even better, is something similar to the FPS gun mouse by Zalman..
« Reply #3 on: Thu, 28 July 2016, 00:03:22 »
Well, I'm not any better at the GO,
But the mouse feels very accurate.. and 0 wrist pain or wrist tweaking....  It's amazing...
143572-0
Offline nmur
  • ಠ_ಠ
« Reply #4 on: Thu, 28 July 2016, 00:07:04 »
what angle is your ergo dox tented at?
this project is super cool btw
« Reply #5 on: Thu, 28 July 2016, 00:08:20 »
I'm tented at 45*, ergodox..
That's the limit given the longest m3 bolts I can find..
Offline nmur
  • ಠ_ಠ
« Reply #6 on: Thu, 28 July 2016, 00:19:00 »
wow that's pretty hardcore!
if only there was a topre ergodox.... can i commission tp to make me one i wonder....
« Reply #7 on: Thu, 28 July 2016, 00:23:41 »
They already make the MuTron, which is essentially Topre-dox..
Offline nmur
  • ಠ_ಠ
« Reply #8 on: Thu, 28 July 2016, 00:27:59 »
yeah it's the only option but it's like $500 and has a split ANSI layout
i'm drooling at the thought of a proper ergodox with topre pcb/plate support though
« Reply #9 on: Mon, 08 August 2016, 16:57:31 »
2 Weeks in w/ the Ergopwn..
Pain free...!!
Confident this is the way to go...
All wrist and forearm rigidness is gone..
No longer get that pain/soreness on the --inside-- of the --middle-- of forearm right behind the wrist..
Offline ErgoMacros
« Reply #10 on: Thu, 09 February 2017, 14:31:18 »
Hi,
I thought after this posting I saw you mention that using the the Logitech G304 as donor for decent sensors simplified the operation. (no longer needs the hub), but I can't find that reference any longer.
Was I dreaming? or can you point me to that reference?
Thank you.
Today's quote: '...“but then the customer successfully broke that.”
« Reply #11 on: Thu, 09 February 2017, 16:34:51 »
Hi,
Thank you.
If the mouse uses a mechanical rotary encoder wheel , you probably won't need the hub..
I say probably because I don't actually own any of the new logitech mechanical wheel mouse.
the Gpro, and 403  But overall,  i'm 90% sure it will work, because that rotary encoder looks to be the generic type used in nearly Every other mouse.
I think g304 is only international, haven't seen one.
« Reply #12 on: Thu, 09 February 2017, 19:53:51 »
Vertical gaming mouse is an oxymoron - I think you meant, Vertical mouse that you could potentially play games with
Offline ErgoMacros
« Reply #13 on: Thu, 09 February 2017, 20:02:07 »
Ah yes, I meant the g403 not the g304. I was working from fallible memory. Thanks.
« Reply #14 on: Thu, 09 February 2017, 20:15:13 »
Hahahaha..
After I got used to it,   it works just as well for me..   and the comfort is unparallel..
But since I'm one of probably 20 people who's got a bolt together mouse..   the Science is still out..
But that DOES make Tp4 a Leading authority on the subject..  .. hahahahaha
« Reply #15 on: Thu, 09 February 2017, 20:23:17 »
ff
« Reply #16 on: Thu, 09 February 2017, 20:30:11 »
asdf
Offline Sintpinty
  • Carbon Based Life Form
  • she/her/they/them/any except he him
    • My Roblox Profile
« Reply #17 on: Sat, 23 November 2019, 06:46:41 »
Materials Required:
Key Insight:
G303/G302 good
