Author Topic: Rice part-II, Presoaking and Hydration  (Read 47308 times)
« on: Sat, 06 December 2014, 08:51:17 »
HYDRATION formula:
To Determine perfect amount of water to cook rice..
You must determine the water loss due to cooking time.  This must be done experimentally.
The formula serves as a guide as to the baseline of water needed assuming 0%-evaporative loss.
w = r(p-s)/(1-p)
w = r(p-0.12)/(1-p)
r : weight of rice (g)
s : % moisture level of uncooked rice (may assume 0.12 -the industry standard-)
p : % final hydration level, ideally between (0.58 and 0.64)<-- your choice
w : volume of additional water (g or ml)
Pre-soaking
An overnight experiment to find necessary PRE-soaking time for rice..
It is necessary to pre-soak, pre-hydrate rice, because this greatly improves the evenness of the rice texture after cooking.
The purpose is.. too long... is a waste of time.. too short and you don't get max pre-hydration.
Experimental results:
Interval soaked (minutes) vs % increase in water weight.
30 minutes,_______________________22%
45 minutes,_______________________27%
60 minutes,_______________________29%
75 minutes,_______________________30%
90 minutes,_______________________34%
120 minutes,______________________29%
180 minutes,______________________29%
2x overnight bowls,___________30% and 33%
SO it seems maximum rice soaking peaks @ about 1 hour..
No need to soak for Overnight folks..
Re: Rice part-II, Presoaking
« Reply #1 on: Sat, 06 December 2014, 10:10:21 »
Question guys..
evaporation loss..
Is there a way to calculate this or does it have to be determined empirically ..
I realize every pot is different, but what if I have a good round pot, and I'll be steaming the rice on an Inner container..
such that the water level is slightly over the rice, and the surface is a smooth flat surface, and NOT beneath the rice..
can I use  gs = Θ A (xs - x) / 3600  ??
because, the issue here is,,  humidity ratio..  and area..
« Reply #2 on: Sat, 06 December 2014, 17:00:34 »
Only if you're using older brittle rice or eating glutenous rice, in which case: why haven't you made the change to basmati rice yet?
« Last Edit: Sat, 06 December 2014, 17:02:10 by noisyturtle »
« Reply #3 on: Sat, 06 December 2014, 17:46:54 »
Because sushi rice is the best kind?
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
« Reply #4 on: Sat, 06 December 2014, 17:54:35 »
But it's so bad for you. Full of glutenous sugars, empty calories, and carbs :(
4 bowls of white rice = 50 teaspoons of sugar
Plus white rice prevents the body's absorption of certain vitamins. Zinc/iron/B vitamins
« Reply #5 on: Sat, 06 December 2014, 17:56:23 »
You're eating the crappy bleached kind. The authentic dehusked kind is a lot better.
To be fair though, if I can't get the nice kind I'll eat basmati.
« Reply #6 on: Sat, 06 December 2014, 20:02:08 »
Rice _IS NOT_  and _HAS NOT_  ever been -Bad for You-
If you need energy.. rice has that in spades..
But if your life is just  ass + chair..  then you may become overcharged..
Rice overall, is still one of the more natural energy solutions.. vs highly processed flours and flour products..
Offline Firebolt1914
  • POM Overlord
« Reply #7 on: Tue, 09 December 2014, 17:38:45 »
Mixed rice is the best rice :). Although a simple bowl of white rice is never ever bad. It's fun being korean sometimes cause of all the rice.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #9 on: Tue, 09 December 2014, 17:45:41 »
Picture foodie pron this plz
Offline Novus
  • Mondai nothing~
« Reply #10 on: Tue, 09 December 2014, 17:46:03 »
what's mixed rice.
Mixed rice is purple rice
  • POM Overlord
« Reply #11 on: Tue, 09 December 2014, 17:47:07 »
what's mixed rice.
Yeah, but usually mixed rice has more peas and other bits than just purple rice.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #12 on: Wed, 10 December 2014, 08:08:36 »
Jesus guys, i feel like i'm missing out and been doing this wrong my entire life cause i literally have just been washing rice and throwing it in the rice cooker EVERY time i make rice. i've never pre-soaked or anything, does it really make that big of a difference?
GON NerD TKL DTA Edition
« Reply #13 on: Wed, 10 December 2014, 10:09:40 »
Presoaking gets a more even cook..
be sure to also apply my hydration function to achieve perfect liquid levels
You will also need to account for evaporation.. this has to be done empirically.
This won't work for a rice cooker.. only pot
For anyone that doesn't want to find -s-,  just assume it's 0.12
Market forces would push producers to keep moisture level there anyway.. so it's a fine assumption.
I tested 3 different types of rice in the house.. they all fall around 12%..
w = r(p-s)/(1-p)
w = r(p-0.12)/(1-p)
s : % moisture level of uncooked rice (may assume 0.12)
Offline Blackehart
Re: Rice part-II, Presoaking and Hydration
« Reply #14 on: Mon, 29 August 2016, 11:22:09 »
Necrobump...
sophistimacated formulas for cooking rice?
Granted I live below sea level....
put rice in non-stick pot.
add water.
check water level by inserting clean middle finger.
Let rice level out and touch the rice.
Water should be at or just slightly above first knuckle.
Throw pot on stove on high till it boils feverishly (big boils).
Throw cover on.
Lower heat to low.
Let simmer for 10 mins (12 if it more than half the pot).
Turn heat off and let sit covered for 5 mins (or just leave it there till you're done cooking your stir-fry or whatever else you got going).
Yes, I've been tempted multiple times to buy a nice rice cooker...but this method hasn't failed me.
EDIT: this is for white rices; bhasmati, plain long, jasmin, etc....brown rice takes too long :p
^_^
« Reply #15 on: Mon, 29 August 2016, 13:37:55 »
Necrobump...
add water.
Throw cover on.
Lower heat to low.
^_^
This works fine for smaller quantities but it's hard to adjust because the evaporation and cooking rate is non linear..
In the end, it's gonna be a bit of trial and error anyway,   but overall , the purpose of putting numbers on it, is to create a baseline.
Offline iLLucionist
  • Topre is Love.
« Reply #16 on: Tue, 25 October 2016, 05:12:24 »
This. Is. F**KING GENIUS.
« Reply #17 on: Tue, 25 October 2016, 20:40:15 »
Rice is a must have in the Sifo's diet.
Offline YoshiCaps
  • yes, oh god no.
« Reply #18 on: Sat, 03 December 2016, 21:55:05 »
if you soaked it overnight it would get mushy. I have a pressure cooker so I can cook it in 20 minuetes no soak
wich is good for beans and rice cause beans have to be soaked as well
« Last Edit: Sat, 03 December 2016, 22:08:24 by yoshilikesmxbrowns »
hi.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #19 on: Sat, 03 December 2016, 23:26:52 »
9/10, TP...excellent work  :)) :)) :))
Offline iLLucionist
  • Topre is Love.
« Reply #20 on: Sat, 29 April 2017, 10:35:01 »
TP honest question. Why does every recipe state that I should wash my rice till water is clear before I steam my rice manually? Why does the rice need to be cleaned / clear water? Because typicall quick cook rice is just poor boiling water, cook for 8 minutes, separate water, let rest for another 10 mins.
« Reply #21 on: Sat, 29 April 2017, 11:24:30 »
It's a throwback tradition.
by washing the rice, you remove some surface starch and that leads to a small difference in final rice texture.  it will be less sticky offering more clarity and grain separation.
rice also did not used to be as clean as is processed in our modern industrial facilities. there was dust and debris and often weevils (rice/grain bugs).
For these reasons it was prudent to wash rice.
However,  modern day rice, because it's already presorted, the grain composition is very good and cracking is low, so this leads to very low leeching of starches into the cooking water vs old rice.
Modern rice will produce a good final cooked texture even without diligent washing..
It's also much a cleaner product today.
