Author Topic: Tp4 Reviews 2016's Top microSD Cards. (Detailed Benchmarks Inside)  (Read 17757 times)
« on: Sat, 31 December 2016, 22:09:38 »
So, you're looking to buy a new microSD card..
But Which one... ??
64GB Samsung Pro Select (to replace Pro+ which is being retired)
64GB Sandisk Extreme Pro (UHS-1 version)
64GB Sandisk Extreme (2016 Edition)
/Tp4 Demystifies 2016's Top cards..
Tp4 has benched the 64GB iterations of the popular cards. They're FASTER than the 128GB versions.
Did 3 Runs, formatted between Each run. No unexpected deviation, Pictures are of FRESH out of box runs.
Benchmarking Hardware_ PC + 2 Different Cellofone
          Lexar Workflow SR2 Card Reader via USB3.0
          Cpu: Intel 2500k @ 5GHz
          Memory: Corsair DDR3 - 2133Mhz
          Mock-Fill-Data: 33,000 files, size range from 1kb to 300MB
          Cpu speed locked to 5Ghz through Bios, no downclocking, high performance mode set in
          windows, Timer-Resolution App engaged to minimize DPC-Latency
Software_
          Crystal Disk Mark
          (Picture 1, Fresh out of the box, Picture 2, 86% filled w/ Mock Data)
          ATTO Disk Benchmark
          (Picture 1 only, Fresh out of the box, Bench)
          A1 SD Bench
          Used on Cellofones
Samsung PRO Select 64GB
156558-0
86% filled
156560-1
Sandisk Extreme Pro (UHS-1 Ver.) 64GB
156562-2
86% filled
156564-3
Sandisk Extreme (2016 Ver.) 64GB
156566-4
86% filled
156568-5
Benchmarks from My Cellofone, android 6: A1 SD Bench, Advanced benchmark enabled
Samsung Pro Select:
Random I/O__             8.28    MB/s Read  1.65    MB/s Write
Accurate sequential__  65.16  MB/s Read  40.66  MB/s Write
Sandisk Extreme Pro:
Random I/O__             8.01    MB/s Read  1.76    MB/s Write
Accurate sequential__  69.67  MB/s Read  55.13  MB/s Write
Sandisk Extreme:
Random I/O__             10.97  MB/s Read  2.97    MB/s Write
Accurate sequential__  76.41  MB/s Read  54.49  MB/s Write
Benchmarks from Different Cellofone 2, android 5: A1 SD Bench, Advanced benchmark enabled
Samsung Pro Select:
Random I/O__             17.01  MB/s Read  3.14    MB/s Write
Accurate sequential__  41.15  MB/s Read  34.61  MB/s Write
Random I/O__             17.03  MB/s Read  2.90  MB/s Write
Accurate sequential__  39.97  MB/s Read  37.0  MB/s Write
Sandisk Extreme:
Random I/O__             17.08  MB/s Read  4.07  MB/s Write
Accurate sequential__  40.71  MB/s Read  35.9  MB/s Write
Observations and Conclusion:
So, It was odd that the Samsung card was so much slower in my Samsung phone, as Samsung has been caught red-handed cheating in Benchmarks by Review sites, You'd think samsung would cheat with their cards in their own fone..  But alas this doesn't seem to be the case.
An explanation for this lower performance would be perhaps Samsung card use a more involved wear-leveling algorithm.   This would inherently slow down the cards, because the card needs to take more time with its allocation.
Another possibility that Samsung is slower is that, they've tuned the controller for more durable continuous writing. These cards get real hot during continuous I/O, so you can tune either for peak performance which heats up, or tune it for continuous where it's more towards warm.
I know for a fact (contacted sandisk) that their extreme lines are NOT designed for continuous i/o and it in fact voids the warranty.
The Sandisk Extreme (2016) is a newer iteration than the Original Sandisk Extremes sold in 2014 which were TLC.
The Newly Produced Line of Sandisk Extreme and Ex Pro are now MLC..
The fact that the Sandisk Extreme PRO is slower than the Extreme in my fone would Indicated that the Newest 2016 iteration of the Extreme either has a stronger microcontroller, or uses less aggressive wear leveling.
The Extreme only loses to the Extreme Pro and Samsung Pro Select in Sequential Write,  Something that really doesn't matter because these cards are not going into expensive DSLRs..
These chips are mostly going into Cellphones and GoPros,  both of which only writes at a Max speed of 7.5MB/s for their 4K video recording.
They would certainly work well in a raspberry pi for ur pi server needs.
It's impossible to test durability, because there's no way any one guy would have a large sample size of these cards, since they're not commonly used in bulk quantities.
Based on these tests,  Sandisk Extreme seems to be the Best Choice for Performance...
Samsung Pro+ is being retired, replaced by Pro Select
NEW line of Sandisk Extreme Pro is now UHS-II only, the UHS-I cards of the Older PRO line is now called Extreme Plus.
UPDATE:
Sandisk Extreme 128GB,   the 128gb is indeed slower than the 64gb variant .. (Not by much) .. but slower..
Performance in Cellfone
sandisk extreme 128gb 2016
Random Performance:
7.83 MB/s Read     3.06 MB/s  Write
Sequential Performance:
76.14 MB/s Read     50.71  MB/s Write
158258-6
Update: Nov 26, 2018
256GB  Samsung Evo Select
Kind of lack luster.. hrrrmm...
207835-7
Offline rabbitfire
Re: Tp4 Reviews 2016's Top microSD Cards. (Detailed Benchmarks Inside)
« Reply #1 on: Sun, 01 January 2017, 05:14:01 »
thanks for your review!  :thumb:
Offline fanpeople
« Reply #2 on: Sun, 01 January 2017, 17:04:22 »
Did you find it helpful in your quest for a new sd card?
« Reply #3 on: Tue, 03 January 2017, 20:43:06 »
Just benched a 128gb.. it's def slower.
will report when full bench completes.
Offline rabbitfire
« Reply #4 on: Wed, 04 January 2017, 03:21:08 »
Looking for a new SD card for my GoPro
Did my appreciation to threat starter bother you?  :))
« Last Edit: Wed, 04 January 2017, 03:23:14 by rabbitfire »
Offline fanpeople
« Reply #5 on: Wed, 04 January 2017, 03:52:50 »
It was a genuine question, did my question regarding your appreciation to threat starter bother you?
Offline rabbitfire
« Reply #6 on: Thu, 05 January 2017, 08:17:44 »
Haha..thanks! It does not bother me at all dude. I'm not a **** like you.
Offline ygor
  • eat a butt, monkey lord
« Reply #7 on: Thu, 05 January 2017, 08:23:11 »
Damn. It's tough out here on the streets of microSD.
Offline fanpeople
« Reply #8 on: Thu, 05 January 2017, 23:32:48 »
I was asking a serious question, re-calibrate your forum interpretive skills. no need to call me a **** and if you feel the need to call me a **** at least turn your child filter off so I know what **** is.
« Reply #9 on: Fri, 06 January 2017, 00:28:01 »
Uh oh.. fanpeople you've engaged maximum ruffle..
hahahahahahahahahaha...
Relax ya'll..
Take some pictures...
@ rabbitfire:
Don't waste money on these extreme cards rabbitfire..
The only reason I tested them (borrowed from my photography guy),  is because I need Random i/o performance.
If you're using a Go Pro,  that only writes at a maximum of 7.5MB/s in 4k mode.
So there's absolutely no reason to spend the money on these extreme cards.
For a Go pro, you can safely go with the Samsung Evo/ Evoselect/ Evoplus line..  They will be more than adequate as long as you're not backfilling.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #10 on: Tue, 10 January 2017, 15:55:55 »
Looking for a good 128GB card for my new phone and the Samsung Pro+@€86 looked quite good on paper. You're saying it's not all that?
I mean there is always the Lexar@€169 but that's at double the price. And the Sandisk@€195 is even more expensive around here.
Just looking for something that can handle 4K video (bitrate of 52 Mbps) and lots of data like music files and photos.
« Last Edit: Tue, 10 January 2017, 16:08:32 by JaccoW »
|||My other keyboards :
x
« Reply #11 on: Wed, 11 January 2017, 16:12:11 »
get the sandisk extreme (uhs-1)....   not the extreme plus or extreme pro.
If you look at the benchmarks,  it's pretty clear that the samsung pro select has the weakest random i/o performance.
Sequential is pretty much the same all around..  if you're using it just for video and no apps.. It doesn't matter which one you get..
You should probably consider the EVO line from samsung if you're only worried about videos and no apps..
Apps are what you need the extreme series for.
The two cards you linked to are UHS-2 cards which is why they're expensive..  UHS-2 cellfones do not yet exist .
UHS-2 is for High end DSLR cameras with very high bit rate..
Things like our cellfones and go pro has 4k resolution recording, but it's very low bitrate for 4k..
Even entry level cards will be sufficient.. 60mbit 4k on most hand-mobile devices like the go PRO records at 7.5MB/s  that's it, there's no magic to it.. it's a number..
THe UHS-2 also have slow random i/o performance , but they're not designed for it, so that's expected.
« Reply #12 on: Sun, 22 January 2017, 15:30:40 »
128GB  Sandisk Extreme card..
Random Performance:
PC Performance:
158254-0
« Reply #13 on: Mon, 26 November 2018, 18:32:44 »
207833-0
Offline JianYang
« Reply #14 on: Tue, 27 November 2018, 01:28:49 »
Having personally destroyed a handful of SD cards, I would really like to see some destructive tests (But I understand the hurdle).
May I ask why you are looking for random IO performance? For my application, I can boot from an SD card, and have the rest on a USB SSD.
« Reply #15 on: Tue, 27 November 2018, 09:00:41 »
I load apps onto the card from the phone.. and over time, with photos/videos being deleted, alot of back filling, I noticed that low random i/o cards slow to a crawl..
This is the same in raspberry pi applications.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #16 on: Thu, 29 November 2018, 16:45:14 »
2018 version pls
« Reply #17 on: Thu, 29 November 2018, 20:52:38 »
2018 version pls
One word of warning.. the 2018 version of the sandisk extreme (plus) is much slower than the original 2016 sandisk extreme.
WAyyyyyy slower, 30% reduction in random i/o performance.
Samsung has been mostly consistent.
