Author Topic: Tp4's Deep Grooves  (Read 78417 times)
Tp4's Deep Grooves
« on: Wed, 13 January 2016, 23:17:00 »
Dohrill capz.. Upgraded... M0ar Deep... M0ar POWER
Extra deep gro0ves.. using DCGT 55* carbide blade.
V2 upgrade on left,  V1 on right.
124265-0
V2 is a 2 piece design..  1 Drill Core + 1 Sleeve Ring..
124267-1
--The reason for going 2 piece, is so I can Over-Cut the groove to go Even Deeper.
Comes in Lazer-Cut display case.. old V1 picture.. Acrylic _ Wood HYBRID
124517-2
Re: Tp4's Deep Grooves
« Reply #1 on: Wed, 13 January 2016, 23:17:53 »
Are we digging a hole?
« Reply #2 on: Wed, 13 January 2016, 23:18:37 »
It's so you can come visit me in China Halvy...
Offline whmeltonjr
« Reply #3 on: Wed, 13 January 2016, 23:19:05 »
Do they come in Topre?
« Reply #4 on: Wed, 13 January 2016, 23:19:13 »
It seems as though he activated a trap card
« Reply #5 on: Wed, 13 January 2016, 23:19:27 »
It's possible, if the demand is high enuff..
« Reply #6 on: Wed, 13 January 2016, 23:20:08 »
I'll create armor to survive the molten journey
Offline whmeltonjr
« Reply #7 on: Wed, 13 January 2016, 23:20:26 »
Do they come with bandaids? Or special thimbles?
« Reply #8 on: Wed, 13 January 2016, 23:21:54 »
No, but you could alternatively,  MAN the Fvk up..
JKJK,, I might make a Shattered - Edition, where the tip is blown off with explosives.. and it could come like in a bundle or something.   But,  Even with the "current design.. this is an extremely time consuming cap to machine..
So many little details.
Offline nmur
  • ಠ_ಠ
« Reply #9 on: Wed, 13 January 2016, 23:29:44 »
yay they're back!
is there hope that these will actually be available at some point? they're so sick
« Reply #10 on: Thu, 14 January 2016, 09:19:27 »
yay they're back!
I've recently found a small machine shop that's running on fumes..  they might be able to do a small run at a reasonable price..
But even a small run means at least 30-50 units..
Are there even that many Toppa fans on GH ?.. hahaha
You guys gotta like buy one, and convince all ur friends to buy 1.. hahhahaha..
The second issue is.. the V2 deep groove is extremely time consuming to cut, it roughly triples the machining time..   so... if we had the shop produce V2-s, it'd be somewhere near almost $60 [USD] each..
The V1 would be cheaper around $45..
  • Live long and prosper
« Reply #11 on: Thu, 14 January 2016, 09:21:44 »
v2 looks better
tp thread is tp thread
« Reply #12 on: Thu, 14 January 2016, 09:23:59 »
v2 looks better
I know righ... ??
I'm very proud of them new grooves.. hahaha...
It's tapered just right, to produce a striking- look of Depth..
Notice they're deeper at the base, and very subtle near the tip..
Offline tronbeaver
« Reply #13 on: Thu, 14 January 2016, 09:42:25 »
Wat?
Offline nmur
  • ಠ_ಠ
« Reply #14 on: Thu, 14 January 2016, 09:48:31 »
didn't really notice that before
that's so cool
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #15 on: Thu, 14 January 2016, 09:55:52 »
I want one. I want my keyboard to look like a weapon. Make it happen.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #16 on: Thu, 14 January 2016, 10:21:38 »
Hahaha this must be the least comfortable shape of keycap I've ever seen xD . But it looks really awesome actually xD .
« Reply #17 on: Thu, 14 January 2016, 17:34:40 »
The drill core is an emotional- piece  for me..
The concept of Spiral Power.
To challenge those who merely wish to remain in place.
To constantly improve and grow.
To evolve beyond mere pleasure seeking.
To Incorporate the universe itself into ones perspective..
These are the ideologies I feel was highlighted in Gurren Lagann. And the drill core, the central power, something simple in concept, then Magnified and refined an infinite fold..
Those were the things on my mind when making all the improvements to the cap.
Offline bocahgundul
  • a seal
« Reply #18 on: Thu, 14 January 2016, 17:42:24 »
Can you make a watermelon caps  ^-^
Offline Roibhilin
  • Saver of Humens
« Reply #19 on: Thu, 14 January 2016, 17:42:48 »
What do the stems look like
QFR | Poker II | Quickfire TK
Offline fanpeople
« Reply #20 on: Thu, 14 January 2016, 18:00:15 »
Kinda looks like one of those things you use to manually grind the marjewawannananas up.
PS I don't smoke because drug tests.
« Reply #21 on: Thu, 14 January 2016, 18:03:54 »
just sayin'
NSFW
MOD EDIT: added nsfw tag   ;)
« Last Edit: Thu, 14 January 2016, 21:14:54 by ghostjuggernaut »
"The Trump campaign announced in a letter that Republican candidates and committees are now expected to pay “a minimum of 5% of all fundraising solicitations to Trump National Committee JFC” for using his “name, image, and likeness in fundraising solicitations.”
“Any split that is higher than 5%,” the letter states, “will be seen favorably by the RNC and President Trump's campaign and is routinely reported to the highest levels of leadership within both organizations.”"
Offline nmur
  • ಠ_ಠ
« Reply #22 on: Thu, 14 January 2016, 18:08:43 »
just sayin'
http://www.amazon.com/Size-Matters-KL710-Rectal-Dilators/dp/B002I9YMS2
i really have to stop clicking every damn link while at work without reading it
Offline heedpantsnow
  • Old enough to know better
« Reply #23 on: Thu, 14 January 2016, 19:25:42 »
I thought this was a thread about TP dancing, but now I see it's actually much cooler.  If I put one of these as my Esc key and then whack somebody in my office with it, will it hurt them?
I'm back.
« Reply #24 on: Thu, 14 January 2016, 19:49:46 »
I'm not at the Machine shop today.
The whole upper portion is modeled 100% proportionally Faithful to the Drill core from the Anime.. [Bluray version, the SD version is warped]
The bottom of the curtain is completely flat. and the 4mm stem sticks out beneath it.
You can see the stem a little better in this older picture of the V1..
124344-0
« Reply #25 on: Fri, 15 January 2016, 20:26:05 »
I was going for, if I turned into a llama, and kronk has to get me back to the palace.
« Reply #26 on: Fri, 15 January 2016, 21:03:38 »
Lol :llama:
I'm back.
« Reply #27 on: Sat, 16 January 2016, 10:03:04 »
Tp4 does not support drug use..
Offline fanpeople
« Reply #28 on: Sat, 16 January 2016, 10:14:40 »
does tp4 make the concept of drinking sound appealing even if not intended, yes. Have there have been times that tp4 has said something and it has made me want to drink, yes.
therefore tp4 does support drug use.
« Reply #29 on: Sat, 16 January 2016, 10:18:23 »
Tp4 Quits Drinking initiative.. 2016
Offline fanpeople
« Reply #30 on: Sat, 16 January 2016, 10:21:22 »
Whoa woah woah... lets just think that statement through for a second now. Lets not make any hasty decisions
« Reply #31 on: Sun, 17 January 2016, 19:39:19 »
It's happening.. I'm officially doing it... Starting a counter..
Offline Ramage
« Reply #32 on: Fri, 22 January 2016, 20:00:38 »
Great job TP! Keep it up bro!
Offline Pdub
« Reply #33 on: Fri, 22 January 2016, 22:09:33 »
Offline deductivemonkee
  • Professional Lurker
« Reply #34 on: Sat, 30 January 2016, 19:16:10 »
Don't worry CPT, I got you.
ALPSALPSALPS
oh yeah I saw that crazy **** if that doesn't win I'm deleting my account
/ orthodox - 78g zealios / alps64 - mtsc / sentraq s-60x rgb - gat blues / let's split - 67g zealios / let's split - 67g zealios /
Offline Homenubbie
« Reply #35 on: Sat, 30 January 2016, 19:26:49 »
Offline Macsmasher
« Reply #36 on: Sun, 31 January 2016, 00:30:32 »
I want the three minutes of my life back after reading this thread.
Offline fanpeople
« Reply #37 on: Sun, 31 January 2016, 00:33:56 »
Sorry you should have read the TOS
Your viewing time is non-refundable, but we can exchange that three minutes for another three minutes from any thread in the off topic area.
You will just have to request an exchange at the front counter.
regards
Management
« Reply #38 on: Sun, 31 January 2016, 00:59:24 »
So when you sending me one to review?
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #39 on: Sun, 31 January 2016, 22:06:34 »
TP, are you alive, and is the shop gonna make some? I'll take one, just PM.
« Reply #40 on: Sun, 31 January 2016, 23:01:14 »
I r alive. haha.
But.. alas, guys.. I'm afraid this will not be a possible group buy,  it's just way too expensive in small quantities after the v2 grooves and a secondary polishing scheme I've come up with.
Don't ask me how much,   lets just say it's so expensive, that you don't need to ask..
We'd need at least 100 units to make the v2 polished work.
Offline Macsmasher
« Reply #41 on: Sun, 31 January 2016, 23:53:27 »
regards
Management
Ok, I guess that will do. Do I get interest? Maybe 30 seconds on top of the three minutes?
« Last Edit: Mon, 01 February 2016, 00:19:46 by Macsmasher »
« Reply #42 on: Mon, 01 February 2016, 00:18:48 »
I r alive. haha.
So, how much?
Offline bocahgundul
  • a seal
« Reply #43 on: Mon, 01 February 2016, 02:09:54 »
I r alive. haha.
yeah how much?
Offline jaffers
« Reply #44 on: Mon, 01 February 2016, 02:25:36 »
inb4 the posties steal them and keep them for themselves because you were shipping a weapon in the mail
Offline Bevo
« Reply #45 on: Mon, 01 February 2016, 02:45:37 »
I'll take 87
Offline bocahgundul
  • a seal
« Reply #46 on: Mon, 01 February 2016, 02:47:23 »
I'll take 87
Bro can I ask you what the hell is that creature in your profile pic? slowpoke and llama fusion?
Offline Bevo
« Reply #47 on: Mon, 01 February 2016, 02:51:28 »
I'll take 87
It's slowpoke bunchie :P
Offline fanpeople
« Reply #48 on: Mon, 01 February 2016, 02:55:48 »
I'll take 87
Its what you turn into when you drink fruity lexia.
Offline bocahgundul
  • a seal
« Reply #49 on: Mon, 01 February 2016, 02:57:45 »
I'll take 87
NOW I NEED TO TASTE THIS FRUITY LEXIA  >:D >:D
