Author Topic: KMACS  (Read 1614 times)
Offline Capitalistix
  • Cherry MX Green Disciple
    • Uncanny Electronics
KMACS
« on: Fri, 29 November 2013, 02:13:53 »
Eventually, Id like to get one. Problem is, Ive only ever seen them in TKL format, and I love full boards. Are there any full keyboard KMACs? Or a comparable metal korean custom that is full format?
Offline tbc
Re: KMACS
« Reply #1 on: Fri, 29 November 2013, 02:17:17 »
not a Korean custom keyboard connoisseur, but the only full size I know of is the upcoming nerd 108 by gon.
Offline Moosecraft
  • HHKB Pro
Re: KMACS
« Reply #2 on: Fri, 29 November 2013, 02:17:30 »
Trik X is the only korean fullsize I know of.
Re: KMACS
« Reply #3 on: Fri, 29 November 2013, 02:18:22 »
Check out team red lines subforum, they had a full size buy a while back.
Offline Shadovved
  • King of Stickers (and GBs)
Re: KMACS
« Reply #4 on: Fri, 29 November 2013, 02:20:54 »
The old KMACs can connect with a Kpad using a metal bar. :thumb:
Offline gameaholic
Re: KMACS
« Reply #5 on: Sat, 30 November 2013, 11:05:05 »
Have you tried TKL?  I was worried I wouldn't like not having the numpad but I got used to putting numbers using the top row pretty quick.  I really like having my mouse closer to the keyboard when I am gaming.  I feel like there is less strain on my shoulder.  I actually just got my first 60% board and I am thinking of getting rid of some of my TKL boards.  I do think that fullsize boards should get more love though.  I wonder how much a full size aluminum cases would weigh.  It wouldn't slide around at all on the desk and would make for a good home defense weapon in place of a bat.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Re: KMACS
« Reply #6 on: Sun, 01 December 2013, 05:05:00 »
Lawl, it would. Though I prolly wouldnt grab that right off rip since my Colt is always right on my desk.
I have a few TKL boards (QFR w Greens,  poker w blacks) But Anytime I need to enter numbers whether Im buying something, gaming or whatever, Ive never been fluid with the number row. The numpad however, I have touchtyow ability with and it only requires moving my right hand while myeft stays on homerow. Plus i just like the looks of an OG full board.
Ill have to look into that new nerd 108. I like the idea of the older kmac and pad hooking together but i dont like the idea of shelling out for both :D
