Author Topic: Anyone Here Just Win That Beam-Spring on Ebay?  (Read 1631 times)
Offline 127001
« on: Fri, 29 November 2013, 08:06:10 »
Just curious :D
Offline Game Theory
Re: Anyone Here Just Win That Beam-Spring on Ebay?
« Reply #1 on: Fri, 29 November 2013, 08:10:50 »
Not me
... he's just a poor kid from the stupid ages.
Realforce 104UG | Realforce 91U | IBM SSK | IBM 5251 BeamSpring | IBM Model F XT |  IBM Model F AT | IBM SSK | Filco Majestouch 2 TKL (MX Blue) | KMAC LE (MX Green)| Northgate Omni Key 101 | Avant Stellar Prime
Offline Game Theory
« Reply #2 on: Fri, 29 November 2013, 08:11:11 »
Though I was bidding and I was the original $59 bid.
« Last Edit: Fri, 29 November 2013, 08:12:48 by Game Theory »
Offline 127001
« Reply #3 on: Fri, 29 November 2013, 08:17:02 »
I had a 157 auction snipe set :P, apparently that was too optimistic though...
I was a little worried about that space bar and a lot of the keys are bent. Still woulda been nice though.
I like to know more about the board from whoever won it eventually.
Offline Game Theory
« Reply #4 on: Fri, 29 November 2013, 08:20:54 »
The bent keys could be straightened.
I'll post the same advice I gave of deskthority incase someone here won it:
It anyone here wins this, rock the keys to and fro to remove them. Not left and right. Some of the keys seem to have bent stems already but you can straighten them but do not try to straighten them with the key caps attached as you can break a key caps mount point! From the 4th picture it looks like the rubber contamination shield (Canadian made beam spring) will need to be removed which isn't that much of a project.
If it smells try putting it in the same container with ground coffee (pre-brewing).
Offline 127001
« Reply #5 on: Fri, 29 November 2013, 08:29:44 »
Good to know, I have one with two bent keys I'd like to fix up.
Thanks
