Author Topic: need pic of buckling rubber sleeves in ibm's quiet touch board  (Read 2817 times)
Offline wellington1869
« on: Tue, 20 January 2009, 11:48:39 »
title says it all; i'm wondering if those buckling rubber sleeves can be placed around the springs in regular buckling springs (thus contributing some kind of muting effect but still combining in some way with the existing spring?).  what do you think?
using: ms 7000/Das 3
Offline itlnstln
« Reply #1 on: Tue, 20 January 2009, 12:21:41 »
You might want to do a search.  iMav has posted pics of the sleeves before.
Offline itlnstln
« Reply #2 on: Tue, 20 January 2009, 12:22:11 »
Also, do you think this might add too much resistance?
Offline iMav
  • geekhack creator/founder
« Reply #3 on: Tue, 20 January 2009, 13:48:45 »
The "buckling rubber sleeves" are in the M4 series of keyboards.  Those are extremely short throw (compared to the Model M's).  I don't think they are of the right dimensions to be useful at all in a Model M.
Quiet touch M's don't use these.  They use a rubber dome sheet that lays over the entire set of membrane sheets.
Rubber dome sheet:
Rubber sleeve:
« Reply #4 on: Tue, 20 January 2009, 15:03:02 »
thanks for the deets imav. You're right, the rubber sleeve looks way too thick and fat to be useful around the regular springs...
