Author Topic: M10 with ANGRY KEY  (Read 80333 times)
Offline cmr
M10 with ANGRY KEY
« on: Tue, 20 January 2009, 15:14:41 »
perhaps now i won't be tempted to smash my M10 with my fist when I have a server that's not cooperating....
(yes, it's a real, working pause/break key! just my luck this novelty keycap was made to fit a cherry key stem!)
Offline bhtooefr
    • bhtooefr.org
M10 with ANGRY KEY
« Reply #1 on: Tue, 20 January 2009, 18:02:54 »
That'd be a badass escape key.
Offline Chloe
  • Switch Kitten
M10 with ANGRY KEY
« Reply #2 on: Tue, 20 January 2009, 18:03:43 »
That's lucky. My panic key didn't come with a proper stem.
Offline cmr
M10 with ANGRY KEY
« Reply #3 on: Tue, 20 January 2009, 18:25:02 »
hmm. maybe i'll move it over to the escape position....
a coworker of mine produced a red PANIC keycap upon seeing this, but unfortunately it won't fit a Cherry stem.
Offline Chloe
  • Switch Kitten
M10 with ANGRY KEY
« Reply #4 on: Tue, 20 January 2009, 18:30:17 »
I had to melt the stem and sand it down to get it to fit an ML switch. It could probably fit an MX switch if you fill it with some epoxy putty.
Offline cmr
M10 with ANGRY KEY
« Reply #5 on: Tue, 20 January 2009, 18:35:44 »
well, the PANIC one's not mine, so i'll pass on modifying it
but the X%&#! cap looks pretty great over in the Esc position, so i think it'll stay there.
Offline cheater1034
M10 with ANGRY KEY
« Reply #6 on: Tue, 20 January 2009, 21:38:02 »
lol, i need to get myself an any key, panic key, and @#!* key
Just because they would look awesome :\
Linux Kernel for desktops: http://zen-kernel.org
IRC: irc.rizon.net #zen-sources
ML: http://groups.google.com/group/zen_kernel
Use it! Supported on any distribution, managed through git.
Current Keyboard: Filco FKBN87M/EB (Brown Cherry)
Offline cmr
M10 with ANGRY KEY
« Reply #7 on: Wed, 21 January 2009, 02:00:00 »
ah yes, much better indeed
Offline itlnstln
M10 with ANGRY KEY
« Reply #8 on: Wed, 21 January 2009, 06:46:57 »
Did you buy the key, or did you make it?  If you bought it, do they make one for Alps switches?
Offline cmr
M10 with ANGRY KEY
« Reply #9 on: Wed, 21 January 2009, 09:28:59 »
it was left behind by a coworker who recently retired. one of the desktop people pulled it off of his keyboard and left it on a shelf in the storage room.
Offline itlnstln
M10 with ANGRY KEY
« Reply #10 on: Wed, 21 January 2009, 09:55:13 »
I found a few online stores with a set of 8 keycaps, but they look a little cheesy.  I did not find one that looks like yours, though.
Offline cmr
M10 with ANGRY KEY
« Reply #11 on: Wed, 21 January 2009, 12:34:19 »
can you post the link?
nevermind, i found them. you're right, not so great.
Offline fkeidjn
M10 with ANGRY KEY
« Reply #12 on: Wed, 04 February 2009, 02:18:31 »
How about red colored?
Kinesis Keypad - Filco FKBN104M/EB - Unitek space-saver - Acer 6511-TW - Apple Extended II (M3501) - Scorpius M10 - Cherry G80-1800, AT - SGI Granite - vintage Fujitsu - IBM Model M, 101 and mini - Model F, 84-key AT - Dell AT101W - Northgate 101
