Author Topic: G710+ Keycaps  (Read 4416 times)
Offline z3n
G710+ Keycaps
« on: Sat, 30 November 2013, 22:12:52 »
Anyone have any idea which site I should get replacements from with a G710+ keyboard? (Cherry MX Brown.)
Willing  to pay a fair amount, up to $60. I did do some research so far it looks like Max Keyboards has replacements but I'm uncertain of the quality. Hoping to find a few informed opinions.
Offline Pacifist
  • on hiatus
Re: G710+ Keycaps
« Reply #1 on: Sat, 30 November 2013, 22:47:40 »
get the ducky ones off of mk.com for $40 shipped, plus you can use the MKBFCM code to get 10% off until monday
Offline Flyersfan1
  • Hi!
Re: G710+ Keycaps
« Reply #2 on: Sat, 30 November 2013, 22:48:38 »
There's a sticky in this section with links to some of the key-cap vendors that many geekhackers buy from.  I'm not entirely sure if it's over or not, but Feng was running a group buy for some of Vortex's thick PBT double shots that are quite nice and very reasonably priced, but those would unfortunately limit the back lighting capabilities of your G710+.  If you choose to not go that route, I'd highly recommend checking out Qtan's website, IMSTO's offerings, or the classified section.  Good luck with your search!
Quote from: Photekq
Offline tbc
Re: G710+ Keycaps
« Reply #3 on: Sun, 01 December 2013, 01:09:00 »
guys, be careful what you're recommending him.
remember that the g710+ does NOT have 1.25x mods all the way through like the ducky has
Offline Grendel
Re: G710+ Keycaps
« Reply #4 on: Sun, 01 December 2013, 02:06:27 »
I think the Max sets will fit:
IMHO the Max caps are definitely of better quality than the crap the 710+ comes with.
- I'm game !
Offline berserkfan
Re: G710+ Keycaps
« Reply #5 on: Sun, 01 December 2013, 10:25:14 »
not to sound like an idiot, but if OP is not too particular, I would recommend he stay with his current keycaps.
backlit keycaps are darn hard to come by, and they perpetually fit only the keyboard they are manufactured for. If I remember rightly (a friend has a G710), you can't use the keycaps from a Ducky, Rosewill or Deck to replace the bottom row. And not to mention, the six macro keys on the left side. No matter what he does, OP is doomed to have a keyboard where not all the backlit keycaps match.
Offline z3n
Re: G710+ Keycaps
« Reply #6 on: Sun, 01 December 2013, 11:56:36 »
Thank you for the replies. I don't mind if the macro keys aren't done, since I am not worried about them. (don't use many macro's)
I suppose then, I guess I will try for Max Key caps as long as nobody appears  saying they have had a bad experience w/ Max Keyboard caps. :)
Also, from what I see, backlit keyboard caps are generally bad. Ducky keyboards are generally one of the best choices it looks like, for quality. To bad I did not come across Ducky before now.
Offline Mikey Mo
Re: G710+ Keycaps
« Reply #7 on: Sun, 01 December 2013, 21:51:50 »
l think it haven't some keycaps for sale
