Author Topic: Beyerdynamic DT-880 Pro Headphones (250 Ohm) -$179.60 FSSS or Prime  (Read 1466 times)
Offline missalaire
  • Great Finder of Great Finds
Beyerdynamic DT-880 Pro Headphones (250 Ohm) │ $179.60 FSSS or Prime, AC on Amazon │ Temorary OOS but orderable
Right now you can order the venerable Beyerdynamic DT-880 Pro Headphones [amazon.com](250 Ohm) from Amazon for $211.31. The 15% off coupon is automatically added to your cart which makes the total $179.60. FSSS eligible or Prime applies. They are temporarily OOS from Amazon directly, but still are orderable. If you don't see the Amazon as a listing seller, make sure to choose Amazon.com from More Buying Choices on your right.
http://www.amazon.com/Beyerdynamic-DT-880-Pro-Headphones-250/dp/B001B1QENY/ref=sr_du_1_map?t=slickdeals&tag=slickdeals&ascsubtag=G7NQulpVEeOpeyas14OV6QSIU8_KVDq3_0_0_0&m=ATVPDKIKX0DER&s=electronics&ie=UTF8&qid=1385872141&sr=1-1
