Author Topic: Vista and Cherry G84-4100LCM  (Read 4920 times)
Offline lam47
« on: Wed, 21 January 2009, 04:03:43 »
Anyone know why this shows up as an unrecognised device under Vista?
The PS2 version seems to work fine.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline CX23882
« Reply #1 on: Wed, 21 January 2009, 05:28:59 »
Have you tried it in a different USB port?
Is it the board I sent to you?  Has it just been delivered, because perhaps it has condensation that's freaking it out, from being out in the cold to a warm house.  If you can't get it to work I'll refund your Paypal payment.
Offline lam47
« Reply #2 on: Wed, 21 January 2009, 05:37:52 »
Ive tried a few ports. No luck yet.
Did you have it working in Vista at all ?
This is all I seem to get :(
I'm sure its not your fault though so don't worry.
[/IMG]
Offline lowpoly
« Reply #3 on: Wed, 21 January 2009, 05:43:36 »
Just connected my G84-4100PTMDE to Vista 64. No problems, recognized immediately.
I wonder why mine has a different switch code than your's (T vs C) and why it has the M connector code while being USB. :confused:
Offline lam47
« Reply #4 on: Wed, 21 January 2009, 05:51:58 »
Cheers Lowpoly. I'm running 64 too so not sure what's happened here.
The das and other usb keyboards seem to work fine.
Offline lam47
« Reply #5 on: Wed, 21 January 2009, 05:55:36 »
when I plug it in it the lights flash a few times then this pops up a few times.
Offline CX23882
« Reply #6 on: Wed, 21 January 2009, 06:10:06 »
Quote from: lam47;19063
I had it working in Vista 32-bit on a Dell Dimension E521 (a system known to have very finnicky USB support).
Do you have another system that you can try it on?
Offline lam47
« Reply #7 on: Wed, 21 January 2009, 06:15:38 »
I can try it on the 360 good idea.
Offline lam47
« Reply #8 on: Wed, 21 January 2009, 06:18:46 »
Its working fine on the 360.
Now I need to work out whats up with my PC!
Thanks CX23882
Offline lowpoly
« Reply #9 on: Wed, 21 January 2009, 06:24:11 »
When I connect my HHKB to my laptop I get the same symbol in the taskbar. Different error though, it says voltage overflow or something like that. I then can reset the usb connection and everything works fine. This is only on my laptop though and I blame the laptop. Not the HHKB. My project board works fine on the same port.
Maybe try it on a different machine?
Edit: Too late :)
Offline lam47
« Reply #10 on: Wed, 21 January 2009, 07:14:10 »
It wont even work in my bios so it must be a compatibility issue with my motherboard.
Not to worry.
My friend Laura will like it.
Offline CX23882
« Reply #11 on: Wed, 21 January 2009, 07:58:34 »
It should work with USB 1.x controllers, but have you checked that USB 2.0 support is enabled on your motherboard?  If you only have the one root hub appearing I would suspect that USB 2.0 is disabled, but I might be wrong.
Does it make any difference if the keyboard is connected when the system boots versus only connecting it when the computer is already running?
Offline lam47
« Reply #12 on: Wed, 21 January 2009, 09:23:17 »
No no different. Also I have 2.0 and legacy enabled in the bios.
Its an Asus Crosshair motherboard.
