Author Topic: Questions while designing a new case  (Read 1823 times)
Offline swill
  • builder & enabler
    • swillkb.com
« on: Sun, 01 December 2013, 12:25:13 »
I am working on a new case design right now (will describe better later), and I have some questions.
How hot do the diodes and resistors get on an led capable pcb?  Will I have problems if I completely remove airflow to the back of the pcb?
Offline AGmurdercore
Re: Questions while designing a new case
« Reply #1 on: Sun, 01 December 2013, 14:35:11 »
You really shouldn't have any problems at all if you do this, so don't worry about that.
What the hell am I even doing
Offline Oobly
« Reply #2 on: Mon, 02 December 2013, 02:24:16 »
Not enough to be a problem. Should be just fine. There are enough metal bits in contact with them to transfer heat up to the top surface in an extreme situation anyway.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
