Author Topic: Majestouch Ninja TKL Or QFR  (Read 2813 times)
Offline ~OmIfan~
« on: Tue, 03 December 2013, 01:56:11 »
So, I'am going to buy my first mechanical keyboard. i do have the budget to buy filco MJ Ninja TKL (and i really want it  ;D) but i do want to buy the other stuff. From where i live i could get QFR for about $85 and Filco for about $150
so if i buy QFR i could get the other stuff at the same time i buy the keyboard and if i buy Filco, I will have to wait for about 2 months.
So the question is :
-Should i buy Filco MJ Ninja TKL or QFR? (With the reason  :D )
-Is the Filco worth the price?
-Tell me the advantage if i get the Filco.
and btw i want the MX Blue one.
Re: Majestouch Ninja TKL Or QFR
« Reply #1 on: Tue, 03 December 2013, 04:28:08 »
Welcome to Geekhack!
Either keyboard is fine - both are good quality (although the Filco probably has the edge).
Many people do not like the keycaps on the QFR, so you would probably need to factor in a set of replacement keycaps at about $40 to $100 depending on what ones you get and from where.
Filco has non-detachable cable (AFAIK), QFR has detachable cable.  This might be a factor in your decision if you want to be able to remove the cable.
Offline ~OmIfan~
« Reply #2 on: Tue, 03 December 2013, 05:11:30 »
Thank you for your reply.  :)
I don't really mind the cable whether it's Detachable,Gold Plated or other fancy stuff.
Kinda confused now :(
« Last Edit: Tue, 03 December 2013, 05:14:13 by ~OmIfan~ »
Offline Tony
« Reply #3 on: Tue, 03 December 2013, 05:23:23 »
I have both kinds of keyboards in my collection. Filco TKL has better quality but is more expensive than QFR.
So all depends on your budget.
If you can afford it, go straight for Filco TKL. It will save you a lot of time in the long run. Worths the wait too.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Tue, 03 December 2013, 05:23:37 »
i would go for the Majestouch.
Superb quality board
Offline ~OmIfan~
« Reply #5 on: Tue, 03 December 2013, 05:28:11 »
well thx for the reply. you own a Filco TKL and a QFR, do you notice any difference from those 2 ?
Offline Tony
« Reply #6 on: Tue, 03 December 2013, 05:58:56 »
Of course yes. Filco TKL is better built,  and has better, smoother typing feel. For a newbie these differences may not be so obvious, but seasoned geekhackers will notice it easily. Overall Filco is simply amazing, and QFR is reasonable, so so quality for the price.
You may not feel, comprehend, or understand right now why these differences can worth 80 USD in price, but they do. If you are just newbie, I always suggest to go straight to Filco, since I know that you will eventually get a Filco anyway. To get a Filco as the first keyboard saves you a lot of time and effort.
« Last Edit: Wed, 04 December 2013, 00:47:38 by Tony »
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #7 on: Tue, 03 December 2013, 06:03:57 »
If you can afford it, Filco. IMO they are the most solid MX board out there.
Offline ~OmIfan~
« Reply #8 on: Tue, 03 December 2013, 06:09:58 »
So tempting....
thx for the replies, i'm gonna go for filco then :D
Offline ynrozturk
« Reply #9 on: Tue, 03 December 2013, 07:28:58 »
Yup, Filco gets my vote as well.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline Candyflip
« Reply #10 on: Tue, 03 December 2013, 07:59:17 »
One more vote for the Filco, I am getting one myself  :D
Offline Awful
  • Don't Topre.
« Reply #11 on: Tue, 03 December 2013, 08:06:50 »
Filco for sure. If for no reason other then the hideous cm storm logos.
I hate everything.
Offline dvjz.gh
« Reply #12 on: Tue, 03 December 2013, 12:12:25 »
I've got a qrf Stealth and it's a real well build keyboard  :thumb:
