Author Topic: How do SA profile keycaps compare with DCS keycaps in terms of feel/sound?  (Read 5017 times)
Offline Beca
  • what am i doing with my life
I was thinking about purchasing a Penumbra keyset, but I'm not really sure if the SA profile would be a good fit with the switches I have.
Has anyone tried SA profile keycaps with clears or ergo-clears?
Offline terran5992
  • One With The Cup Rubber
Re: How do SA profile keycaps compare with DCS keycaps in terms of feel/sound?
« Reply #1 on: Wed, 04 December 2013, 07:48:21 »
They are really high profile compared to DCS. I would guess that there would be a little wobble
Offline Beca
« Reply #2 on: Wed, 04 December 2013, 16:35:34 »
Why would it have a little wobble? :o
Offline terran5992
« Reply #3 on: Wed, 04 December 2013, 19:51:53 »
If the keycaps wobble a bit when its on a low profile. Its gonna be amplified on higher keycaps
« Reply #4 on: Wed, 04 December 2013, 23:54:45 »
I'm not sure I follow your logic on this?
Offline MKULTRA
  • telling it how it is
« Reply #5 on: Thu, 05 December 2013, 01:11:26 »
jdcarpe practically creamed himself over them in the last podcast, if that tells you anything.
Offline Beca
« Reply #6 on: Thu, 05 December 2013, 03:09:52 »
GH has a podcast?  :eek: I'mma go check that out.
I wish there was a video of someone typing with SA profile keycaps though :(
« Reply #7 on: Thu, 05 December 2013, 06:52:35 »
Oh i heard. JD likes them brown, thick and smooth.
Offline Belfong
« Reply #8 on: Thu, 05 December 2013, 08:56:41 »
I tried round 4 SPH on my brown switch and while it works ok and no wobbles, I have a problem with the space bar. I think the brown switch cannot take the weight of the space bar as it's not as bouncy as the stock PBT cap.
Offline tricheboars
  • Keyboards are Important!
« Reply #9 on: Thu, 05 December 2013, 12:58:07 »
i own the SA Round 4 "space cadet" set and SA caps definitely wobble.
they are still amazing and it doesn't bother me when i type. but i would be lying if i didn't say there is a wobble.
Offline AuRinBei
« Reply #10 on: Thu, 05 December 2013, 13:45:06 »
Is it the height that's an issue, or is it because they have loose stems?
87u || Poker 2
Offline Beca
« Reply #11 on: Thu, 05 December 2013, 16:00:46 »
Wait, so do they wobble consistently? Because Belfong said they have no wobble but two others say they wobble. Confusing!
Offline Latin00032
« Reply #12 on: Thu, 05 December 2013, 16:55:16 »
I would assume it's the standard amount of wobble in most mx switches, but the height of the SA profile makes it seems worse.
Offline Photoelectric
« Reply #13 on: Thu, 05 December 2013, 16:56:53 »
Switch stickers to the rescue!
Offline Belfong
« Reply #14 on: Fri, 06 December 2013, 01:26:54 »
I think definition of wobble in order. I understand that most mechanical switches, being mechanical and having individual parts moving would inevitably wobble. So, if you rest your finger on a key and trying to move it left and right, the key wobble. Even the HHKB has some sort of wobbling. But to me, those are not wobble. Wobbling is when you type and the moment you move your finger to another key, the one you have just pressed start to shake. That's wobbling to me and the SA profiles doesn't demonstrate that on the MX Brown.
