Author Topic: Where to harvest a Caps Lock without step for a G80-3000?  (Read 2594 times)
Offline spremino
« on: Wed, 04 December 2013, 17:19:36 »
I would like to buy a Cherry G80-3000, but I'm annoyed by its Caps Lock with a step. Could I harvest a Caps Lock without step from an older or cheaper model from Cherry?
I've seen single Caps Lock key caps without step on sale, but apparently they are meant for Filcos an the likes (and they are ABS anyway, which I don't like).
Thanks.
A long space bar... what a waste of space!
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Where to harvest a Caps Lock without step for a G80-3000?
« Reply #1 on: Wed, 04 December 2013, 17:24:23 »
You either would have to stem mod (cut out the stem and epoxy new one in position) a fulltouch caps lock... or if you have a steady hand you can drill the PCB and move the switch. I've never seen a fulltouch MX compatible keycap with 1.25 offset stem spacing.
Offline spremino
« Reply #2 on: Wed, 04 December 2013, 17:56:02 »
Thanks, IvanIvanovich, but a stem mod is not for me  :-[
The Cherry G80-8113HRBUS-2 has a Caps Lock without step (keys for this mod were harvested by one: http://geekhack.org/index.php?topic=36860.0), but I can't see whether the profile of such key cap would fit within a Cherry G80-3000. Otherwise, I suppose I could replace all the keys.
« Reply #3 on: Wed, 04 December 2013, 18:00:29 »
Finding keycap isn't the hard part... the switch is in different position, so the different style stepped and full touch is not interchangeable without modification to keycap or PCB...
Offline spremino
« Reply #4 on: Wed, 04 December 2013, 18:10:54 »
IvanIvanovich, I didn't know that. Thank you.
Well, no G80-3000 for me, then. What a disappointment! The G80 was an affordable way to try Cherry blues.
Offline dragonxx21
« Reply #5 on: Wed, 04 December 2013, 18:17:27 »
If you'd like to try blues on the cheap may I point you to this thread?
http://geekhack.org/index.php?topic=48838.msg1050585#msg1050585
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline spremino
« Reply #6 on: Wed, 04 December 2013, 19:21:12 »
I need an ISO layout, but thanks for your suggestion.
Offline terran5992
  • One With The Cup Rubber
« Reply #7 on: Wed, 04 December 2013, 19:49:27 »
Cherry wants you to spend more money
« Reply #8 on: Wed, 04 December 2013, 19:58:04 »
When it comes to Cherry, stepped is by far the standard. Fulltouch row C caps locks are much more uncommon and only on a handful of models. Pre 1000 models fulltouch row C Control keys were more common with caps lock under right shift.
