Author Topic: Hello from Sweden fellow keyboard lovers.  (Read 2461 times)
Offline jensbond
« on: Wed, 04 December 2013, 19:17:33 »
So i registered here 2 mins ago, i thaught i chould need some expert help, and the after i get that expert help i know enough to give expert help to others.
But first lemme tell something about me, i play Tetris, Brood War and Starcraft2. My favoritue game was Bloodline Champions.
Here is a picture of my keyboard. Now ill try to find a place to get help at making my keyboard a mechanical keyboard without really making it look any different.
I dont have to do a smiley cuz my keyboard does it for me.
Offline eth0s
  • Peace & Love
Re: Hello from Sweden fellow keyboard lovers.
« Reply #1 on: Wed, 04 December 2013, 21:44:17 »
lol.  I'm not sure what you want, but that's an awesome keyboard.
It's rubber dome, I'm sure.
So you want a mechanical keyboard, that looks somewhat like your current rubber dome keyboard?
I guess you can start with this Yellow Filco, and add some purple OEM profile keycaps.  http://www.amazon.com/Filco-Majestouch-2-Action-Keyboard-FKBN104MC/dp/B0060J3VO2/ref=pd_sxp_f_pt
Welcome to GH jensbond!
Offline dragonxx21
« Reply #2 on: Wed, 04 December 2013, 21:48:30 »
I believe they wish to mod it to use mechanical switches.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline eth0s
  • Peace & Love
« Reply #3 on: Wed, 04 December 2013, 21:50:26 »
heehoo, really?  That would be some tiresome and expensive project.  It would easily cost twice as much as a new Filco, but w/e.  My advice is to buy the Filco and add some purple OEM profile keycaps.  And try to get a purple wrist rest.  Better keyboard, and cheaper than the mod plan.
Offline jensbond
« Reply #4 on: Thu, 05 December 2013, 06:01:54 »
Well the one you linked dosent look that similar to my keyboard. And yes i want to try to mod it.
Also i went here just because some guy at a swedish computer forum told me that there was a group buy of custom circut boards here. Just havent found the thread yet  :(
The placement of my keys are just a bit off normal keyboards. So thats why things are gonna be more difficult.
tl:dr i want to make my keyboard mechanical, without changing the looks of it. I can spend up to 400 dollars on modding my keyboard, money aint an issue. Time aint either.
« Last Edit: Thu, 05 December 2013, 06:04:52 by jensbond »
Offline n0rdlad
« Reply #5 on: Thu, 05 December 2013, 14:12:48 »
Haha hur är där min vän? Thas a crazy project u got planned there
- Filco MJ2 104 MX Brown -
Offline Moosecraft
  • HHKB Pro
« Reply #6 on: Thu, 05 December 2013, 14:13:41 »
Swedes represent, welcome to GH
