Author Topic: It's Red!  (Read 6584 times)
Offline Jixr
It's Red!
« on: Thu, 05 December 2013, 18:57:55 »
Hey guys, picked up another QFR, so thought i'd might as well paint, lube, and cap it.
Red case, red plate, mx reds, heart cap for style, as well as my 'Jixr' Spacebar.
hope you like.
Not sure what i'm going to do with it, either sell it or give it away as a christmas present ( have 4 keybaords atm, only need 2 )
« Last Edit: Thu, 05 December 2013, 19:03:43 by Jixr »
Re: It's Red!
« Reply #1 on: Thu, 05 December 2013, 19:38:50 »
moar pics?
Looks great.
Offline Aceru
Re: It's Red!
« Reply #2 on: Thu, 05 December 2013, 19:52:46 »
What kind of paint did you use? It looks amazing!
Offline Jixr
Re: It's Red!
« Reply #3 on: Thu, 05 December 2013, 19:53:56 »
yeah, i'll get more posted. I thought I Had some of the assembly, lubing the switches, painting, etc, turns out you need to put a memory card in your camera occasionally if you want it to work properly.
Offline Jixr
Re: It's Red!
« Reply #4 on: Fri, 06 December 2013, 14:05:33 »
As for the paint I used some off the shelf rustolium, its a gloss finish, which typically i avoid, since gloss finishes are much harder to sand smooth and look nice compared to the matt colors ( like I use on my blue one )
Offline cmadrid
Re: It's Red!
« Reply #5 on: Fri, 27 December 2013, 17:45:43 »
I need to try and make a red top for my QFR to match my new pc case.. this looks great!
Offline cherpalla
Re: It's Red!
« Reply #6 on: Thu, 02 January 2014, 12:03:20 »
Love it.
c h e r
Offline Jixr
Re: It's Red!
« Reply #7 on: Sat, 04 January 2014, 22:36:27 »
thanks, updated it a bit by making a custom sleeved and shortened cable to be connected to my ipad until my poker 2 comes in the mail.
