Author Topic: M13 trackpoint ps2->usb?  (Read 3198 times)
Offline wumpyr
« on: Fri, 23 January 2009, 19:03:41 »
Do you need to use the ps2/usb active converter, like clickykeyboard's one for the trackpoint ps2 on the M13?
I tried a passive converter and it didn't seem to work.  I only have one ps2 port on my thinkpad replicator and if I plug it directly in there, it works fine, but if I would like to enable both keyboard and trackpoint simultaneously, I will need to convert at least one of the ports to usb.  Yes, I could just convert the keyboard port, I know.  This is just an academic question really.
thanks
IBM Model M13 Raven Black \'96, \'97 (2), \'98 (2)
IBM Model M13 Industrial Gray \'96 (2)
IBM Model M Industrial Gray \'88, \'94
IBM Model M White Label 1391401 \'92
IBM Model M International \'95 (2), \'96
IBM Model M 52G9658 \'93
IBM Model M 1370475 Mini \'93
Offline cchan
« Reply #1 on: Fri, 23 January 2009, 19:41:36 »
Does a PS/2 y-adapter work? I believe some of my friends have used that on their laptops with only one PS/2 port to use both a keyboard and mouse with it at the same time. Personally, my laptop has two PS/2 ports on the dock, so I have no need for such a device. But it may well work for you.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline bhtooefr
    • bhtooefr.org
« Reply #2 on: Fri, 23 January 2009, 19:57:17 »
Exactly. You need a Y adapter.
But, for USB, you do need to use an active converter. A passive converter is for a device with a PS/2 plug that can also speak USB itself. Seeing as the M13 predates USB by three or four years... ;)
I've used a Belkin F5U119vE1 with the M13, and it worked... note, though. Plug in the mouse FIRST, *THEN* the keyboard.
Offline wumpyr
« Reply #3 on: Fri, 23 January 2009, 22:07:54 »
Ah ok. Y adapter.  For no particular reason I dismissed that option!
I'm off to buy one, thanks.  I looked through the huge amount of computer stuff I have and couldn't find one.  That'd be right.
I did discover in my hunt though 2 original Novell NE1000 BNC ISA network cards, some 5.25 inch floppies (one having the classic Montezuma's Revenge on it), old intel processors such as an 80286-16 and i386 and the chip extractor tools that go with them!
Offline wumpyr
« Reply #4 on: Fri, 23 January 2009, 23:33:55 »
Bought a Y adapter.  Seems to work fine.  Thanks geeks.
