Author Topic: How rare are international model Ms?  (Read 3082 times)
Offline wumpyr
« on: Fri, 23 January 2009, 21:57:39 »
I would love to get my hands on an Italian layout Model M - classic, spacesaver, m13 - whatever, as long as it is buckling spring.  I'd probably hand over a very decent amount of cash for a good one.
I see there was one sold previously in the clickykeyboard's archive.
What are my chances of finding such a layout? Or should I just give up, roll over and die? ;)
Does anybody have an Italian M they would part with?
thanks
IBM Model M13 Raven Black \'96, \'97 (2), \'98 (2)
IBM Model M13 Industrial Gray \'96 (2)
IBM Model M Industrial Gray \'88, \'94
IBM Model M White Label 1391401 \'92
IBM Model M International \'95 (2), \'96
IBM Model M 52G9658 \'93
IBM Model M 1370475 Mini \'93
Offline xyzzy
« Reply #1 on: Sat, 24 January 2009, 03:29:02 »
International layout Model M have been manufactured mostly in the "classic" version (1391404). Sometimes you can spot one on ebay.it.
Once you have one (or more ;)), you can look for a Unicomp Model M 85key spacesaver (UNI04C6), which is the only M spacesaver with ISO layout ever produced, and swap the keycaps with the 1391404 as you can see here.
Regarding the M13, I've seen some with ISO layout (IIRC french or canadian layout), if you can get one you might be able to do the same keycaps-swap with the 1391404.
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline wumpyr
« Reply #2 on: Sun, 25 January 2009, 00:30:18 »
Excuse my ignorance, are the unicomp keyboards manufactured with key caps+stems or a single key piece like the M13?
Offline iMav
  • geekhack creator/founder
« Reply #3 on: Sun, 25 January 2009, 01:41:59 »
Quote from: wumpyr;19546
Yes.  :)
They offer both, depending on color and preference.
If all you care about is ISO layout with buckling spring, why not simply order a new Model M from Unicomp with blank keycaps?
Offline wumpyr
« Reply #4 on: Sun, 25 January 2009, 03:26:54 »
Hi iMav
Yes, I could, but I would prefer an original Model M :)  Does unicomp sell just the keycaps?  I'll probably take their italian keycaps and retrofit an original ISO Model M.
Offline Etinin
« Reply #5 on: Sun, 25 January 2009, 20:06:59 »
I think they do. You should contact them.
Unicomp SpaceSaver (white)
Only good keyboard due to high shipping costs and import taxes but loving it so far.
Offline wumpyr
« Reply #6 on: Sun, 01 February 2009, 15:11:02 »
Jim Owens from unicomp tells me that they sell a complete button set that are compatible with ibm/lexmark model Ms in most languages for $20. Sweet.
