Author Topic: Alternate Action Cherry MX  (Read 3914 times)
Offline bhtooefr
    • bhtooefr.org
« on: Sat, 24 January 2009, 13:54:11 »
How do the alternate action Cherry MX switches work?
Can you do switch surgery, and install the guts of an alt action switch in the body of a non-alt action switch?
I'm wondering, for lowpoly's keyboard design.
Offline lam47
« Reply #1 on: Sat, 24 January 2009, 17:28:58 »
Can you explain what an alt Cherry is? Its not a term I have seen around the boards.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline bhtooefr
    • bhtooefr.org
« Reply #2 on: Sat, 24 January 2009, 17:37:40 »
Alternate action = press key, locks down, press it again, comes back up.
Like Caps Lock on many ADB keyboards.
Offline lam47
« Reply #3 on: Sat, 24 January 2009, 17:40:43 »
Oh right. I have not seen one of those.
Would be interested to if anyone has a picture.
Thanks.
Offline Chloe
  • Switch Kitten
« Reply #4 on: Sat, 24 January 2009, 17:47:02 »
It looks like you can swap upper housing and stem:
http://blog.dengzhe.com/article.asp?id=252
Offline bhtooefr
    • bhtooefr.org
« Reply #5 on: Sat, 24 January 2009, 17:48:32 »
Perfect.
Offline lam47
« Reply #6 on: Sat, 24 January 2009, 18:02:04 »
Cool look at the little latch on the stem part! Its so dinky.
Offline Chloe
  • Switch Kitten
« Reply #7 on: Sat, 24 January 2009, 18:22:19 »
The latch on ALPS alternate action is even smaller. For the record it is possible to swap upper housing and stem with real ALPS but not with simplified.
