Author Topic: Removing & replacing On Filco stabilizers  (Read 3342 times)
Offline n0rdlad
« on: Tue, 10 December 2013, 05:29:47 »
Had a bit of trouble with my new Filco MJ2 romoving and replacing the larger keys with stabilizers. Is there an easy method Im missing. Please share your technique or a link would be handy. Thanks GH. She's gonna be amazing and I dont want to break those tiny bits of plastic in there
- Filco MJ2 104 MX Brown -
Offline ynrozturk
Re: Removing & replacing On Filco stabilizers
« Reply #1 on: Tue, 10 December 2013, 11:08:48 »
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline n0rdlad
« Reply #2 on: Wed, 11 December 2013, 02:06:11 »
Thank you.. They were a bit tight to get off that way. Wont be playing with them too much till I've got the replacement pbt caps.
Getting rid of the shakey wire sound on the large cap's stabilizers will be something I'll try. I heard cling/sandwich wrap works to quieten the stabilizers. Applying a few layers neatly on the wire to dull the vibrating.
If it works well Ill be sure to post pics of work done
Offline MKULTRA
  • telling it how it is
« Reply #3 on: Wed, 11 December 2013, 02:09:23 »
Make sure you lube your stabs while they are naked!  :cool:
Offline n0rdlad
« Reply #4 on: Wed, 11 December 2013, 04:00:20 »
Like a good quality oil or astroglide? lol
Offline Danule
« Reply #5 on: Fri, 13 December 2013, 17:07:07 »
Lube will quiet the stab wires.
45g Brown Brown Blue
Offline n0rdlad
« Reply #6 on: Sun, 15 December 2013, 14:29:44 »
Whats a good lube for keyboard switches etc?
« Reply #7 on: Sun, 15 December 2013, 14:46:27 »
Krytox
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #8 on: Sun, 15 December 2013, 16:21:30 »
Krytox
To be more specific, Originative sells a Krytox lubricant mix over here: http://www.originativeco.com/collections/accessories/products/lube-kit
You won't find it cheaper. It's difficult to buy Krytox in small amounts and you'll inevitable end up with much more than you need for a single keyboard.
