Author Topic: Black Blank PBT?  (Read 3491 times)
Offline Stevenator21
Black Blank PBT?
« on: Wed, 11 December 2013, 19:34:22 »
Hello,
I am soon getting a Ducky Shine 3 TKL and I was looking to get a black blank PBT keyset. I have looked around for a while and have not found any.
Can anyone point me in a direction to find some?
Any help is awesome,
Steven
Ducky Shine 3 TKL w/ Browns + White LEDs
Offline Michael
  • Formerly Bro Caps
Re: Black Blank PBT?
« Reply #1 on: Wed, 11 December 2013, 19:35:36 »
« Reply #2 on: Wed, 11 December 2013, 19:41:59 »
Here you go
http://geekhack.org/index.php?topic=50935.0
So is the GB pretty much it for blank black PBT? They're not available in an online store anywhere?
Offline Michael
  • Formerly Bro Caps
« Reply #3 on: Wed, 11 December 2013, 19:43:29 »
Here you go
For cherry profile blank and printed black PBT. Those particular ones would not be available in any store, unless you wait until long after the buy - they may show up on taobao.
Offline Pacifist
  • on hiatus
« Reply #4 on: Wed, 11 December 2013, 19:43:47 »
Here you go
Pretty much. There *may* be some other places, but not as good quality and/or avalibility.
BTW the GB needs ~ 300 more orders to start
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Wed, 11 December 2013, 19:45:41 »
Other than my groupbuy, there was some lower quality thin OEM profile KBC and Ducky, but I haven't seen anywhere that actually had them in stock for quite a long time.
« Reply #6 on: Wed, 11 December 2013, 19:48:27 »
Here you go
Okay that would make sense, I think I will buy a set! Also, would the black blanks look good? (Never had a mech so dont know what color combos would look good) Finally, would the Shine LEDs produce an underglow or would the light be more non-existant?
Thanks so much!
« Reply #7 on: Wed, 11 December 2013, 19:49:46 »
Yeah I saw those on MechanicalKeyboards.com. I am definitely going to join the groupbuy, if I am not mistaken, you are running it too!
« Reply #8 on: Wed, 11 December 2013, 19:51:51 »
You should get some underglow with Cherry thicks. Depend on backplate and led color how subtle. If everything is black it would very subtle probably.
« Reply #9 on: Wed, 11 December 2013, 19:59:19 »
Sweet! Should I get blacks with the Shine 3 or should I go for a multicolor palette?
Offline WindyDays
« Reply #10 on: Sat, 14 December 2013, 08:45:46 »
Well 87 Black Blank PBT keycaps aren't that hard to find if you try, though I don't know about profile/thickness.
The only thing I am slightly worried about for the group buy is colour matching a Shine 3, since the colour is referenced from Topre black on blacks.
I have no idea what a Realforce keyboard looks like in real life and photos seem to vary between grey and black, so I'm really not sure.
« Reply #11 on: Sat, 14 December 2013, 13:22:40 »
Thats true, the caps here are more of a dark grey.
Would that go with the Black casing of the Shine 3?
