Author Topic: IBM Displaywriter takeapart  (Read 8355 times)
« on: Thu, 12 December 2013, 23:13:27 »
Cross posted at deskthority:
http://deskthority.net/photos-videos-f8/displaywriter-guts-t7075.html
Ok so I recently got an IBM displaywriter keyboard on eBay. Thanks to all the people that helped me get this once it was found. (The listing didn't say "keyboard" anywhere in the title or description, so it may have slipped past some people's radar.)
Pictures were taken with my galaxy s3 in a moderately lit room, so some are blurry, If you point them out, I'll rephotograph them. Full resolution is on my Flickr, link at the end.
2602678
1982 week 11. Most parts are dated from 1981
Lock key down. This key has no external spring, just the "beam spring". Pushing it down sets a mechanism. Pressing either shift raises it back up. The left shift is "tunable" with a screwdriver. (see later on)
Left shift lock key raise tuning system. The plastic acts as a spring you press against. You can set teh height of the plastic spring by adjusting the nut on the bottom and screw on top
Spacebar stabilizer. I really like this one! the wide plate moves forwards when the stabilizer is pressed. Grease  from IBM is still on the mechanism. (Grease not shown.)
Controller. Closeups showing all the chip labels are on flickr.
Using Webwit's "unique" beamspring naming scheme, we should call this the "IBM Clare Division Keyboard". :D (Image is of the label on the cable)
OK on to the cool PCB shots!
Notice on this one there are 8 strobes. 4 on each side run the full width of the KB. The need for this becomes apparent when we see the back. The up down alternation is critical to the design. There are 12 sense lines.
Right of PCB. Notice the alternation on the far right function keys.
This is the back, so the far left corresponds to the right of the previous image. Notice they are in parallel! When I first saw this I was at first dumbfounded. That would mean this KB was a low KRO and makes no sense whatsoever. Why did IBM do it this way, when they had a good already established circuit for the rest? Then I flipped it back, noticed the alternation and it all became clear. The alternation is so they can have parallel sense lines for the keys. I do not know how this affects things, but I feel like keeping the sense lines short is a good idea.
Longest sense lines are for the spacebar and keys on that row. They are not paralleled like others. Makes sense to me, though I am only starting to understand IBM capacitive circuits.
Obligatory backlit PCB image. I'll get my roommate to scan the PCB in properly sometime.
Fly plates and associated hardware
Keycaps are cleaning now in a mug on top of the frige.
Ok that was fun. Feel free to ask questions!
edit: corrected sense/strobe terminology.
« Last Edit: Thu, 12 December 2013, 23:41:20 by dorkvader »
Offline Wildcard
  • When caffeine isn't enough
Re: IBM Displaywriter takeapart
« Reply #1 on: Thu, 12 December 2013, 23:25:13 »
Great tear down and write-up
Offline Aer Fixus
  • And now, back to lurking...
« Reply #2 on: Fri, 13 December 2013, 00:30:21 »
Sweet. I really want to understand how the IBM capacitive switches work, especially from a programming standpoint.
               SOON: IN PROGRESS:
I lie all the time.... I really don't even like keyboards
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Fri, 13 December 2013, 04:54:14 »
How does it feel?
Offline Game Theory
« Reply #4 on: Fri, 13 December 2013, 06:17:46 »
Great and educational photos and write up.
... he's just a poor kid from the stupid ages.
Realforce 104UG | Realforce 91U | IBM SSK | IBM 5251 BeamSpring | IBM Model F XT |  IBM Model F AT | IBM SSK | Filco Majestouch 2 TKL (MX Blue) | KMAC LE (MX Green)| Northgate Omni Key 101 | Avant Stellar Prime
Offline JPG
  • Model F is my new passion!
« Reply #5 on: Fri, 13 December 2013, 06:38:21 »
Proud to be Canadian right now seeing this was made in Canada!
Nice find  :thumb:
Offline Game Theory
« Reply #6 on: Fri, 13 December 2013, 06:58:22 »
My 5251 was also made in Canada too.
« Reply #7 on: Fri, 13 December 2013, 07:09:31 »
Do you have a picture of the whole keyboard and not a closeup shot? I'm curious to see what the whole unit looks like.
Offline 0100010
  • Not Sure
« Reply #8 on: Fri, 13 December 2013, 08:14:43 »
Would imagine it looks a lot like this :
Offline 127001
« Reply #9 on: Fri, 13 December 2013, 08:29:39 »
Great detail shots  :D, it'll be cool to see when you bring it in your trip.
Offline mr_a500
« Reply #10 on: Fri, 13 December 2013, 13:44:23 »
Nice find  :thumb:
Most of the beam spring keyboards were made in Canada. I'm typing this on a Canadian made 3278. It's great that some of the best keyboards ever made were made in Canada. (...by an American company... but that's another story ;))
« Reply #11 on: Fri, 13 December 2013, 13:56:13 »
Thanks all!
Should be in the flickr album. If not, I'll take another one.
I tried to keep this post to new information that you can't look up elsewhere. There are pictures of DWs elsewhere online (taken by better photographers than me), so I kept them out of the post.
Most beamsprings were, if I recall correctly.
How does it feel?
Close to a selectric, actually. The switches are a little loose and wobbly (due to the old mat inside. I will possibly replace it with something better sometime. Otherwise it's light and clicky, like a lighter model F I Guess.
Nice find  :thumb:
When I visited in 2010, Canada was Awesome!
Yep that's it. There's also a version with a 'bigass' enter and a nonsplit leftshift for 2 fewer keys, but it's less common from what I was able to determine.
Hopefully the keycaps will be clean by then.
My selectric says it was made in NY, and it's still my favourite keyboard, though the beam spring is pretty close. :)
« Last Edit: Fri, 13 December 2013, 13:58:07 by dorkvader »
Offline E TwentyNine
    • Some of My Keyboards
« Reply #12 on: Fri, 13 December 2013, 14:31:38 »
This is a great writeup, thanks.  Regarding the selectric, I had access to them when I was younger and I will never forget, well first the hum of the thing when you turned it on, but more importantly how when you typed when the key reached a certain point it seemed to fall out from under your finger.
Wonder if I could hook one of those up to a computer...
« Reply #13 on: Fri, 13 December 2013, 14:37:06 »
Yes, they're excellent. I have plans for converting mine with optical sensors (so as not to change the keyfeel), but I have to make sure they're thin enough. An alternative is to put a small neodymium magnet on each typebar and have a hall effect sensor nearby. I have checked and there is enough room for either.
Offline ch_123
« Reply #14 on: Sun, 15 December 2013, 05:26:38 »
Did yours have the mechanical latch on the caps lock key?
The "Clare Division" label is almost certainly from the manufacturer of the label as opposed to the keyboard itself. Some of the Model F terminal keyboards also had cable labels (but usually on the inside of the keyboard and not outside). My 3276 beam spring has a handwritten label on the cable with no company name, but the connector has the manufacturer name molded onto the back:
« Reply #15 on: Tue, 17 December 2013, 14:53:45 »
I would really love to see this done.  In the meantime, this will have to keep me occupied.
Offline mougrim
« Reply #16 on: Sun, 18 May 2014, 04:09:33 »
Hmm... and how to connect one to a PC? Is it even possible? I know God send to us Soarer, but did he tried to build a converter for beam spring?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
« Reply #17 on: Sun, 18 May 2014, 23:35:24 »
I think he replaced the controller chip with a teensy, much like what was done with the IBM chinese / japanese (I call them "pingmaster") keyboards.
But Xwhatsit has a prototype controller already that I will want to try and report back on.
Offline mougrim
« Reply #18 on: Mon, 19 May 2014, 01:22:06 »
Hmm... If it works, I think you'll write about it here, right?
Anyway, it's an interesting board - and I like shape of keys on it ;)
