Author Topic: SOLVED:IBM Model F 122 key: are key caps on modifiers compatible with Model M's?  (Read 1329 times)
Offline spremino
Is it possible to replace the key caps with step on the bottom row modifiers of an IBM Model F 122 key with key caps from a Model M? I would prefer modifier keys without step.
Thanks.
« Last Edit: Fri, 13 December 2013, 10:08:04 by spremino »
A long space bar... what a waste of space!
Re: IBM Model F 122 key: are key caps on modifiers compatible with Model M's?
« Reply #1 on: Fri, 13 December 2013, 09:57:55 »
Yes
FWIW, this is a great question for the Simple Questions Simple Answers thread
« Last Edit: Fri, 13 December 2013, 09:59:39 by CPTBadAss »
