Author Topic: Does anyone know what keyboard this is?  (Read 3209 times)
Offline Aggression
« on: Sun, 15 December 2013, 16:01:07 »
Doesn't seem to be a Filco or a Leopold. Perhaps some Korean custom?
« Last Edit: Sun, 15 December 2013, 16:04:51 by Aggression »
Offline Candyflip
Re: Does anyone know what keyboard this is?
« Reply #1 on: Sun, 15 December 2013, 16:23:31 »
I believe INnoVation uses the fc700r with blue switches, but this one doesn't seem like it just because of the cable, hmm I can't really tell just from these pics..
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Sun, 15 December 2013, 16:26:29 »
With that body style and where the cable mini jack is I wanna say it's some custom like a KMAC or similar.
Offline beauthegamer
« Reply #3 on: Mon, 16 December 2013, 08:46:48 »
My best guess is an LZ-87 or an LZ-S (87 key version). My reasoning is that those both have a removable cable on the far right and I believe the LED that you can see in the first picture is actually under the pause/break key, not an caps/scroll lock indicator since the light you can see is so far to the right. After searching around, I found that feng has a blue LZ-S for sale here: http://geekhack.org/index.php?topic=51097 and you can see in his first picture of it that it has an LED on the pause/break key. I also found someone having trouble turning off the LED under their pause/break key here: http://geekhack.org/index.php?topic=48407. I can't seem to find a reason for a pause/break LED though.
If anyone with an LZ-87/86 or an LZ-S can comment on this, that would be great, because I am also quite curious what keyboard Innovation is using.
Filco Majestouch 2 Ninja with wood blue case and reds | HHKB Pro II non-printed black | Phantom with ergo clears
« Reply #4 on: Mon, 16 December 2013, 08:57:49 »
Unless he's changed his gear, he is using a Leopold FC700R. Typically SC2 players don't really like changing their keyboards since they get very used to what they have.
Another picture
Thread on SC2 Players' keyboards
« Reply #5 on: Mon, 16 December 2013, 09:21:34 »
Another picture
I would normally agree with you, but just look at where the usb cable is plugged in the OP and compare it to the first picture you linked. Its hard to tell in your picture, but the cable on an FC700R plugs in under the keyboard in the middle like this:
Also, in the pictures in the OP it looks like he is now using black switches, but in the pictures you posted it looks like he has blue switches (its hard to tell, but if you look very closely you can just barely see a blue switch in the F1 location that is missing a keycap).
I could very well be wrong (I follow SC2 as well and have noticed very few keyboard changes apart from sponsor/team changes that force the player to change keyboards), but I just don't think he's using an FC700R in the OP's pictures.
« Reply #6 on: Mon, 16 December 2013, 09:27:17 »
Hm ok. I don't think it's a custom though. Typically pro-SC2 players don't use customs for whatever reason. This thread is guessing he's using a WASD V2 TKL which makes more sense to me.
Edit: Conveniently, a WASD V2 TKL just popped up in the Spy with some decent pictures for reference.
« Last Edit: Mon, 16 December 2013, 09:46:50 by CPTBadAss »
« Reply #7 on: Mon, 16 December 2013, 09:45:28 »
Edit: Conviently, a WASD V2 TKL just popped up in the Spy with some decent pictures for reference.
I found this picture from DH Bucharest:
where you can pretty clearly see orb keyboard feet. WASD keyboards have feet that look like this:
You can also see a striped look to the case of his keyboard, which makes me think it is a custom with an acrylic case.
Of course, it is possible he switched keyboards again since DH Bucharest, but I find that unlikely. You can kind of see a bit of a striped look in the second picture of the OP, but that could be due to the quality of the picture.
« Reply #8 on: Mon, 16 December 2013, 09:48:17 »
Whoa! Never seen his keyboard at that angle. I'm totally out of guesses. Never seen feet like that before lol. And I don't think it's striped like you said. Just how the picture was taken.
Offline yasuo
  • spanengan puyeng newbie
« Reply #9 on: Mon, 16 December 2013, 09:49:50 »
USB MINI B in right,i see :)
Logitech MK220 Colemak DH
« Reply #10 on: Mon, 16 December 2013, 09:51:11 »
GH seemed to compress the image so it is hard to tell but if you look at the source on Acer's website here: http://cdn.aceresport.com/media/uploads/2013/09/dreamhack_bucharest_2013_day_2_0005.jpg you can see the striping better.
« Reply #11 on: Mon, 16 December 2013, 09:53:16 »
Ah that's what you meant by striping. Gotcha. So it's a layered acrylic case. Wonder if its a custom acrylic case with like an A.87 in it?
« Reply #12 on: Mon, 16 December 2013, 09:54:10 »
That's what I'm thinking as well.
Edit: I found someone on youtube that has what looks like the same exact case.
In the description he says its has an A.87 inside. So you are most likely correct.
« Last Edit: Mon, 16 December 2013, 09:55:54 by beauthegamer »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #13 on: Mon, 16 December 2013, 11:11:03 »
did anyone notice the red legends?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Aggression
« Reply #14 on: Wed, 18 December 2013, 16:07:01 »
Oh wow, you guys really came through. Good job  :thumb:
I would've probably never been able to identify that on my own.
