Author Topic: Stabilizers for my KMAC2  (Read 2390 times)
Offline Steve Cosgrove
« on: Tue, 17 December 2013, 03:45:48 »
Please help. I'm confused and now getting desperate
I am in the UK and assembling a KMAC2 keyboard. I have everything I need except stabilizers.
Which type will work on my PCB and which type will work on my plate?
Which ones are the best?
Where in the UK can I get them?
Can someone give me an explanation of the difference between plate and PCB mounted stabilizers in general?
Will Costar stabilizers fit?
Thanks Guys.
Offline meiosis
  • Time
Re: Stabilizers for my KMAC2
« Reply #1 on: Tue, 17 December 2013, 04:59:52 »
Cherry PCB stabilizers,
I believe people take them off of Leopold or Poker keyboards..
as for 7x spacebar they bend a new wire I believe.
Keyboards:
Aripeko TKL
Offline terran5992
  • One With The Cup Rubber
« Reply #2 on: Tue, 17 December 2013, 05:58:54 »
Why not costar stabalizers?
Offline Saviant
« Reply #3 on: Tue, 17 December 2013, 06:44:46 »
As far as I am aware the KMAC do not support Costar only cherry stabs.
« Reply #4 on: Tue, 17 December 2013, 07:05:59 »
Costar stabilizers are plate mount, and the KMAC does not support plate mount stabs.
http://www.gonskeyboardworks.com/stabilizers/18-pcb-mount-stabilizers.html
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Tue, 17 December 2013, 11:38:19 »
I suggest to grab some cheap G80 1000/3000 winkeyless off German ebay or something. Most of time there is something to find for under 20EUR and you get all the stabs, some switches and nice keycaps. Example.
« Reply #6 on: Tue, 17 December 2013, 11:47:20 »
I agree with Ivan.  I also did the same with a Wyse PCE board.
Offline Wildcard
  • When caffeine isn't enough
« Reply #7 on: Sat, 21 December 2013, 15:50:08 »
All my cherry stabilizers were salvaged from old cherry boards. Costar stabs can be bought from WASDkeyboards.com, however as it was mentioned, the KMAC 2 sadly doesn't accept these.
