Author Topic: Filco 2 Ninja Keycaps  (Read 3050 times)
Offline lolkey
« on: Thu, 19 December 2013, 09:52:23 »
I just got my first mech keyboard around a week ago and everything is great, except the blank top keycaps. I'm not sure what it is, but after 10-15 min of playing an fps game where my fingers are constantly pressed on the WASD keys, they feel like they become coated with a thin film of gunk/oil and it's a really awkward feeling that bothers me. I'm sure this is some type of oil from my fingers, but I'm coming from a scissor switch apple keyboard and never had this issue with that keyboard.
I've read that the Filcos use cheap keycaps, so could this be the case? Would a replacement set of some quality caps fix the issue?
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
  • Live long and prosper
Re: Filco 2 Ninja Keycaps
« Reply #1 on: Thu, 19 December 2013, 10:08:29 »
Sounds like you could use some PBT keycaps...
tp thread is tp thread
Offline lolkey
« Reply #2 on: Thu, 19 December 2013, 10:20:20 »
What's the texture like on PBT? The ones I have now seem very thin and the surface is very slippery smooth.
Also where to get PBT set for a FILCO2? Is there a popular set most people tend to get?
« Reply #3 on: Thu, 19 December 2013, 10:25:22 »
PBT has a better texture to it, not as smooth and soft as ABS.
Any PBT set with a standard layout should work with your Filco. There's actually a group-buy going on right now for a 104/105 thick-PBT keyset, and they're offering blanks or black-on-black dyesubed legends. Link here: http://geekhack.org/index.php?topic=50935.0
« Reply #4 on: Thu, 19 December 2013, 13:13:52 »
If it is mainly WASD while gaming, you could try looking for a set of just PBT WASD to start with.
If that drastically improves things, then start searching for a full set.
Offline PointyFox
« Reply #5 on: Thu, 19 December 2013, 13:30:40 »
PBT keycaps tend to have a dryer, more powdery feel to them.
« Reply #6 on: Thu, 19 December 2013, 20:40:37 »
Good description!
Offline terran5992
  • One With The Cup Rubber
« Reply #7 on: Thu, 19 December 2013, 22:22:20 »
It feels like smooth sandpaper
« Reply #8 on: Fri, 20 December 2013, 00:14:21 »
Smooth sandpaper - you mean like paper? ;)
Offline terran5992
« Reply #9 on: Fri, 20 December 2013, 08:14:32 »
Yea i guess that works well as a description :)
