Author Topic: Trying to locate DayDream kits...  (Read 3814 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« on: Thu, 19 December 2013, 23:31:04 »
I have been looking for these kits to purchase. Can anyone help:
http://www.aliexpress.com/item-img/Daydream-white-mechanical-keyboard-backlight-cherry-shaft-heterochrosis-lamp-cover-by/1505353864.html
Any help from all you GeekHaxxorific lurkers and posters would greatly be appreciated!
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline terran5992
  • One With The Cup Rubber
Re: Trying to locate DayDream kits...
« Reply #1 on: Thu, 19 December 2013, 23:41:27 »
You looking for led color changers or the caps?
heres the color changers
http://geekhack.org/index.php?topic=51126.0
Offline Pacifist
  • on hiatus
« Reply #2 on: Thu, 19 December 2013, 23:42:14 »
you want the taobao link?
Offline Pacifist
  • on hiatus
« Reply #3 on: Thu, 19 December 2013, 23:42:43 »
if so just go search the IC forum for my thread then at the top should be a link
Offline laffindude
« Reply #4 on: Fri, 20 December 2013, 04:12:36 »
They are pretty bad. They make the LEDs way too dim.
Offline Wildcard
  • When caffeine isn't enough
« Reply #5 on: Fri, 20 December 2013, 14:44:31 »
That's what I've been hearing. I wonder if they could have used better materials perhaps? Seems like the cover's I've seen aren't that transparent.
« Reply #6 on: Fri, 20 December 2013, 14:47:50 »
qtan sells these now as well
