Author Topic: Help with Cherry G-80 11900 cable :(  (Read 1924 times)
Offline DesktopAssassin
« on: Fri, 20 December 2013, 12:11:05 »
Hey guys sooo.. my g80 11900 trackpad keyboard with mx blacks needed a clean and being honest im a noob to keyboards and cant remember where my strain relief was when i opened her up if any of you would like to share the location that would be quite handy :) (it's the USB one)
« Last Edit: Fri, 20 December 2013, 14:01:52 by DesktopAssassin »
Soon to be : Cherry G8 11900 (black mx) :)
Re: Help :( i don't know where my strain relief was when i took my g80 apart
« Reply #1 on: Fri, 20 December 2013, 13:52:20 »
i should probably mention the "strain Relief" is the plastic piece in the inside of the case on the usb cable
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Help with Cherry G-80 11900 cable :(
« Reply #2 on: Fri, 20 December 2013, 14:24:41 »
The rubber strain relief should slot into plastic recess on the top of shell.
« Reply #3 on: Fri, 20 December 2013, 14:34:12 »
it doesent fit :( if this is wat you mean (sorry for horrendous image quality) but thanks anyway :)
Offline Wildcard
  • When caffeine isn't enough
« Reply #4 on: Fri, 20 December 2013, 14:37:07 »
It looks like the strain relief doesn't go "into" the slot on this board, but rather sits on the inside of the shell with the cable going out of that hole. It should fit, you probably just have to rotate it around.
« Reply #5 on: Fri, 20 December 2013, 14:44:11 »
 :) :) :) :) i think i found it  it turns out theres a little space under the pcb where it can be routed out thanks for the help
Offline Wildcard
« Reply #6 on: Fri, 20 December 2013, 14:50:14 »
No problem, enjoy the Cherry :)
