Author Topic: Beyerdynamic dt880 Pro / Premium for $195@Amazon / $239@Massdrop  (Read 2935 times)
Offline hungryfingers
« on: Sat, 21 December 2013, 01:20:22 »
The Massdrop for Beyerdynamic DT880s hit its max goal, pushing the price for Premiums down to $239. Seems like a deal, down from a $300+ MSRP.
However.
Amazon, meanwhile, has the DT880 Pros for $195.
The difference between the two models appears negligible (per head-fi), so the Amazon price looks pretty good by comparison.
Edit: Just saw that missalaire beat me to this by a wide margin, but I'm not so sure the 15% discount from before is still active.
« Last Edit: Sat, 21 December 2013, 01:23:22 by hungryfingers »
Offline terran5992
  • One With The Cup Rubber
Re: Beyerdynamic dt880 Pro / Premium for $195@Amazon / $239@Massdrop
« Reply #1 on: Sun, 22 December 2013, 03:25:43 »
Owch, Pretty expensive except for audiophiles
« Reply #2 on: Mon, 23 December 2013, 05:28:19 »
Well, if you want something less expensive but reasonably well regarded, Amazon has Koss Porta Pros for $25 (head-fi reviews).
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #3 on: Mon, 23 December 2013, 07:09:06 »
If you want to go even cheaper but something that sounds the same (uses the same drivers, I believe), and I think they are even more comfortable too:
http://www.amazon.com/Koss-KSC75-Portable-Stereophone-Headphones/dp/B0006B486K/ref=sr_1_1?ie=UTF8&qid=1387804138&sr=8-1&keywords=ksc75
« Reply #4 on: Mon, 23 December 2013, 07:10:26 »
^^ wish those were closed!
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #5 on: Mon, 23 December 2013, 07:39:53 »
As if the HHKB wasn't expensive... -_- (I used to own one too)
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #6 on: Mon, 23 December 2013, 21:20:37 »
anyone know how would the 880 premium compare against the AD900s (open) i have right now. AD900 becoming more and more uncomfortable as they keep sliding off my head.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #7 on: Mon, 23 December 2013, 21:29:11 »
Ooo. I currently have the A900Xs (closed), and from what I've read on headfi, the ATs are supposedly more favored as they're less drowned out by bass, and has better highs and mids. I'd assume this would be a similar case with the AD900s. Unless you're looking for more bass, I'd stick with your AD900s. I'll be getting AD900Xs in a few weeks, so I guess I'll have to do a comparison with it against the A900Xs, as this hasn't really been done much.
I do agree that the Beyerdynamics look amazingly comfy. You can fix your "sliding off head" issue with the elastic band trick. I have a big head so the wing support of the ATs work wonders for me.
Offline Meistershank
« Reply #8 on: Wed, 01 January 2014, 21:47:54 »
Well, wish I would have held off on getting those HD 558s, lol.
