Author Topic: Lubricating Cherry MX Switches?  (Read 2871 times)
Offline Nonmouse
« on: Sat, 21 December 2013, 16:46:04 »
Sooo... I have a Cherry G80-8113 with white MX keyswitches that's suffered large dousings of juice in the keyboard a couple of times  (3 year-old child in the house...)  The first time, I tried to dry it out by pulling the keys, cleaning it, etc., but several keys were still, well, sticky, so I took the plunge and hosed it out with the showerhead, let it dry several days, then plugged it back in.  Somewhat to my surprise, it worked out great- no sticky keys, everything functioned normally.  Success!
So, the second time it happened, I went straight to giving Mr. Keyboard a shower.  Not so much success this time.  While they work, and they're not sticky as in feeling like there's gum in the keys, most of the keys are very stiff, return slowly and sometimes get stuck dowwwwwwwwn...  In short, they feel like they're dry, rather than gummed up.
Does anybody have any recommendations for lubricating them?  Preferably a penetrating lubricant, since while I could take apart all 136 keys and dab some lube in them... I'd rather not.
Offline Pacifist
  • on hiatus
Re: Lubricating Cherry MX Switches?
« Reply #1 on: Sat, 21 December 2013, 17:12:19 »
without opening its hard to get all the lube in but its possible
sherry at originative has lube for sale. just take one of the smaller syringe headers and shoot some into a depressed switch
Offline Tony
« Reply #2 on: Sat, 21 December 2013, 18:03:55 »
I suppose this time your keyboard need a thorough, meticulous bath with body lotion instead of a mere shower.
You should buy the exact lubricant, otherwise keys will keep on stuck, or lose bump.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #3 on: Sat, 21 December 2013, 18:15:36 »
I recommend the Cherry MX Switch Lubrication Guide, using the lubricant you can buy from Originative. Could you do it differently? Sure, and it'll be ****ty.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Sat, 21 December 2013, 19:51:27 »
Check out WFD's Video
