Author Topic: [IC] Macross / Robotech inspired set (was: VF-1S)  (Read 56687 times)
Offline StylinGreymon
  • Keyboard Hipstar
Re: Macross / Robotech inspired set (was: VF-1S)
« Reply #150 on: Thu, 30 January 2014, 01:48:27 »
What is this BoB?
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #151 on: Thu, 30 January 2014, 01:53:36 »
Matt: Could you consider to add to the BoB a second 2.25x shift key? Sorry if this comment is out of place, and that it should be moved to the corresponding thread. I do not want to cause any confusion.
Two 2.25u? For the Leopold? Remember that Leopold has weird mount points for the shift keys (at least so I heard). Anyway I believe the macross mods kit pretty much covers every keyboard on the planet :) (except for ergo dox and other extremes).
And also I wonder if the two 1x keys in the ISO set should be labeled with the appropriate UK legends. I know other languages are different, but I think ISO users may benefit of having some references in these two keys. Also the backslash key will fit most of ISO based languages.
BoB will have all ISO languages.
UK layout has |\ to the right of the left shift, most other ISO layouts have <>. Since nobody chimed in regarding a UK layout (in more than a month) I'd say I'll keep 2 blanks for Macross.
What is this BoB?
It's a PBT Beige set. We are waiting for SP to release the PBT spacebar to start the GB.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #152 on: Thu, 30 January 2014, 03:51:16 »
just to clarify.
this is going to be DSA!
« Reply #153 on: Thu, 30 January 2014, 03:53:58 »
Macross is cool!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #154 on: Thu, 30 January 2014, 03:54:41 »
Macross is cool!
you can say it twice!
« Reply #155 on: Thu, 30 January 2014, 03:57:59 »
Macross is cool!
Macross is cool!
Macross is cool!
Should I say it three times? :p
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #156 on: Thu, 30 January 2014, 05:50:25 »
just to clarify.
As it should be, as long as DCS is avoided at all costs.  Thank you.
« Reply #157 on: Thu, 30 January 2014, 05:51:53 »
just to clarify.
Bro, just don't take me to a dark alley and hurt me if I disagree.
Offline moonexe
« Reply #158 on: Thu, 30 January 2014, 07:06:14 »
May be interested if I get a job in the near future. It looks pretty. :D
Possible to include colemak home keys?
G80-3000, MX brown           -           Filco Majestouch 2 HAKUA TKL+TK, MX brown, JIS Layout
« Reply #159 on: Thu, 30 January 2014, 07:12:06 »
Get that job!
Offline moonexe
« Reply #160 on: Thu, 30 January 2014, 07:18:51 »
If only I had friends, then I could do that "Hey, hook me up with a job yeh?" thing everyone seems to do. :(
But yes. Job hunting here I come. :rolleyes:
« Reply #161 on: Thu, 30 January 2014, 07:28:41 »
Give this guy a job! I like him!
Offline Elrick
  • Hype Master
« Reply #162 on: Thu, 30 January 2014, 07:54:40 »
But yes. Job hunting here I come. ::)
You bet, even if it's selling dope on street corners  8) .  You should have enough within a few days.
Offline ideus
  • Björkö.
« Reply #163 on: Thu, 30 January 2014, 08:02:47 »
Macross is covered, I meant to have the same for BoB. And shift mounts are standard as any other board. Any standard shift key in 2.25u fits the Leo. Non standard stem positions are in the spacebar only.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #164 on: Thu, 30 January 2014, 08:36:27 »
good to know ideus, thanks.
anyway yes, the PBT set will include the 2.25u additional shift (I have ha 660M myself :P)
Offline ideus
  • Björkö.
« Reply #165 on: Thu, 30 January 2014, 08:45:39 »
anyway yes, the PBT set will include the 2.25u additional shift (I have ha 660M myself :p )
Are all Italians equally awesome? Thank you for the work to keep this nice hobby running.
Offline moonexe
« Reply #166 on: Thu, 30 January 2014, 11:58:55 »
I don't like the risks involved. They don't have mechanical keyboards in jail do they?
Although rent would be cheaper :))
Offline Elrick
  • Hype Master
« Reply #167 on: Thu, 30 January 2014, 16:58:58 »
Just depends on how young you are?  You will pay up one way or another in jail.  Just make sure you end up in solitary after you shank someone in the throat with your sharpened toothbrush handle, that way you could avoid any bum action at night  :thumb: .
Just make sure you let everyone know you're one crazy-motherfvcker and you may be safe.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #168 on: Thu, 30 January 2014, 17:03:42 »
I agree, this set needs DSA Profile keys.
It's too awesome oldskool not to be.  ;D
From left to right
SA, DCS, DSA
(I know Captain Max here is from Macross 7, bite me. He's awesome  :p )
|||My other keyboards :
x
Offline moonexe
« Reply #169 on: Thu, 30 January 2014, 17:18:33 »
I wonder if I could find a way to set things on fire without a lighter... :rolleyes:
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #170 on: Mon, 03 February 2014, 17:54:55 »
this might start as soon as tomorrow! :)
Offline ideus
  • Björkö.
« Reply #171 on: Mon, 03 February 2014, 19:16:31 »
Nice. So tomorrow February the 4th everybody should jump into this nice set GB.
Offline Elrick
  • Hype Master
« Reply #172 on: Mon, 03 February 2014, 20:57:59 »
YES, hoping to wipe away tears of disappointment in not getting what I want in another Group Buy, but I won't mention it here........
At least a decent choice of DSA has been chosen for this nice feature set.  Don't change anything, just stick to the final design and everything will go over perfectly  :thumb: .
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #173 on: Mon, 03 February 2014, 22:40:36 »
this is going down? awesome!
  • Keyboard Hipstar
« Reply #174 on: Tue, 04 February 2014, 00:03:54 »
Nice, I can't wait.
Offline regack
« Reply #175 on: Tue, 04 February 2014, 07:32:13 »
Ok, it's tomorrow now.... :D
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #176 on: Tue, 04 February 2014, 08:19:57 »
waiting for SP to wake up :P
Offline ideus
  • Björkö.
« Reply #177 on: Tue, 04 February 2014, 08:22:10 »
You said today! Sure, we can wait for some more hours though... :)
Offline regack
« Reply #178 on: Tue, 04 February 2014, 14:22:41 »
It seems to be live.
- interface is a bit clunky to select all of the 'child deals' - they need a better way to handle this
- checkout is... not working for me
- hopefully more people sign up because I'm at $201 right now....
« Last Edit: Tue, 04 February 2014, 14:27:31 by regack »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #179 on: Tue, 04 February 2014, 15:16:55 »
Set is live http://geekhack.org/index.php?topic=54334.msg1216886
some hiccups are understood, they are frenetically working on it, but the service is killer!
Offline Excessive
  • Signature Plastics
« Reply #180 on: Sun, 09 February 2014, 11:11:32 »
Hey guys sorry for the difficulties with SP's new group buy site.
We have the checkout all fixed, we're using paypal now, and we managed to get our international shipping rates down to $15.
If you run into any problems or have suggestions - please let me know. We are working every day to improve this so that the site ends up being exactly what the community wants.
Offline pasph
« Reply #181 on: Sun, 09 February 2014, 11:51:24 »
Please give the option to set the "state" field, in account information, to blank.
Offline Excessive
« Reply #182 on: Sun, 09 February 2014, 11:59:29 »
Yea we can do that. I should be able to have that done by tomorrow.
Offline pasph
« Reply #183 on: Sun, 09 February 2014, 12:07:05 »
Offline Skull_Angel
« Reply #184 on: Sat, 08 March 2014, 14:08:33 »
edit: moved to the group buy page.
« Last Edit: Sat, 08 March 2014, 14:13:15 by Skull_Angel »
