Author Topic: Model M Space Saver with Removable Key Caps  (Read 4459 times)
Offline Biggs
« on: Sun, 01 February 2009, 13:58:10 »
How do you determine if one has removable key caps (i.e. caps + stem)?  Did IBM officialy made one with a grey logo?
Offline bigpook
« Reply #1 on: Sun, 01 February 2009, 14:37:09 »
The key caps come off pretty easily if I remember correctly. Don't know about the grey logo.
Offline lal
« Reply #2 on: Sun, 01 February 2009, 15:06:12 »
According to the table on wikipedia there are at least two different versions of the space saver. Model no. 1391472 has two-part keys and grey logo, model no. 1397681 has single-part keys and blue logo. The keys are removable in any case.
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline Biggs
« Reply #3 on: Sun, 01 February 2009, 15:31:41 »
Quote from: lal;20495
Are you sure the 1391472 has 2-piece keys (stem and cap)?
Stem:
Cap:
Offline lal
« Reply #4 on: Sun, 01 February 2009, 16:01:36 »
Quote from: Biggs;20498
No, I'm not sure. The wikipedia table says so. You could browse through clickykeyboards space saver section and do some analysis. One random 1391472 I just picked out did *not* have two-piece keys.
Offline lam47
« Reply #5 on: Sun, 01 February 2009, 18:48:15 »
Mine had removable caps 1394047 uni04c6
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline sandy55
« Reply #6 on: Sun, 01 February 2009, 22:28:32 »
Mines are;
1391472, 1987 made: single-part key
1393278, 2003 made: two-part key, gray IBM loge. NIB but need surgery.
Offline iMav
  • geekhack creator/founder
« Reply #7 on: Mon, 02 February 2009, 05:41:07 »
My 1393278 has two piece keys as well.
Offline sandy55
« Reply #8 on: Mon, 02 February 2009, 06:22:54 »
Hi iMav,
What happened with the IBM logo ?  Did Jim *shave* ai-bee-em off from round base plate before they shipped it to you ?
Offline iMav
« Reply #9 on: Mon, 02 February 2009, 07:10:06 »
Quote from: sandy55;20582
Hi iMav,
No.  This is one they assembled new from old stock for me.  It had never been IBM-badged.
