Author Topic: So my hhkp2 refuses to work on my laptop....  (Read 4935 times)
Offline Bluemercury
« on: Sun, 01 February 2009, 17:35:57 »
Does anoyne has experience this problem, ive been using it from some time but now i plug the usb cable but it has stuttering and slow respons........it seems to be working well on other computers...:S
My das keyboard 2 works fine with the laptop....seems to be only the HHKP....:S
Collection:
Das Keyboard II
Model M5-2
Model M5-1(considering selling this one)
Cherry G80-3000LCMPO with black switches
Cherry G80-5000HAMPO (Brown switches)
McAlly96
HHKP2 BNx2
Offline lowpoly
« Reply #1 on: Sun, 01 February 2009, 18:11:51 »
It doesn't work well with my Toshiba notebook. If I have it plugged in and switch the notebook on then some keys in the upper right won't work. :confused: When I re-plug it I get a 'USB voltage exceeded' error. After resetting the USB port everything is fine. That notebook has other USB issues so it's probably the notebook.
Maybe try a USB hub?
Offline Bluemercury
« Reply #2 on: Sun, 01 February 2009, 18:43:06 »
Quote from: lowpoly;20518
its strange because it has been working well....i mean only today when i plugged in a usb pen in the keyboard did this started to happen....it seems to be working well in my desktop, and ive thought it might have been the keyboard hub that went dead...but in my desktop i plugged the mouse in the HHKP and its working fine.......strange.....i think it may also have been the chipsed update drivers....might have messed with the usb controllers.
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline bhtooefr
    • bhtooefr.org
« Reply #3 on: Sun, 01 February 2009, 18:46:32 »
You might try plugging the keyboard into the same port as you normally plug it in, and plug the drive in on the same port that you plugged it into.
Then, uninstall the driver for the drive, then the hub, then the keyboard, unplug the drive from the keyboard, and the keyboard from the computer, reboot, then plug the keyboard back in.
Offline Bluemercury
« Reply #4 on: Sun, 01 February 2009, 20:05:59 »
Quote from: bhtooefr;20522
wow that's some confusing stuff, i dont have any driver, i assume windows auto install it....
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline bhtooefr
    • bhtooefr.org
« Reply #5 on: Sun, 01 February 2009, 20:34:49 »
Correct. And, you'd be doing all of this in Device Manager.
(Win+R, devmgmt.msc, then pop open Universal Serial Bus controllers, with the devices in question all UNPLUGGED. When you plug them in, you'll see them come up in the list.)
Offline Bluemercury
« Reply #6 on: Mon, 02 February 2009, 09:48:48 »
Quote from: bhtooefr;20544
ill need to try this later at home, thanks.
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline Bluemercury
« Reply #7 on: Fri, 06 February 2009, 19:16:31 »
The keyboard keeps getting delayed response...i press and after only a while it respond...dont know if it might the chipset drivers....
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline bhtooefr
    • bhtooefr.org
« Reply #8 on: Fri, 06 February 2009, 19:21:11 »
This one's not going to make any sense, but does the laptop have SpeedStep? If so, enable it, set it to use a slow profile on battery, and a fast one on AC. Unplug the laptop from AC, plug in the keyboard, then plug in the AC adapter.
It just might work.
(I've had on my previous two ThinkPads keyboard lag in some games, and changing CPU speed while the affected program was running usually fixed it. My current one doesn't have that problem, though.)
Offline Bluemercury
« Reply #9 on: Fri, 06 February 2009, 19:52:57 »
Quote from: bhtooefr;20982
It just might work.
whats speedstep??
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline bhtooefr
    • bhtooefr.org
« Reply #10 on: Fri, 06 February 2009, 20:00:03 »
SpeedStep = a technology on Intel processors, mainly mobile processors, that underclocks the CPU to save battery.
Offline Bluemercury
« Reply #11 on: Fri, 06 February 2009, 20:04:14 »
Quote from: bhtooefr;20986
where can i see it?
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline Bluemercury
« Reply #12 on: Fri, 06 February 2009, 20:34:40 »
Well go figure i used a 1.1 usb hub, connected the hhkp2 through it and now it works, this must have been because of an update to the bios i did to my clevo m860tu, cant see anything else....
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline bhtooefr
    • bhtooefr.org
« Reply #13 on: Fri, 06 February 2009, 22:52:53 »
SpeedStep is in the Windows power settings on XP and higher, I believe.
Offline skriefal
« Reply #14 on: Fri, 06 February 2009, 23:25:40 »
It also must be enabled in the BIOS, where it is often referred to as EIST (Enhanced Intel Speedstep Technology).
Offline bhtooefr
    • bhtooefr.org
« Reply #15 on: Fri, 06 February 2009, 23:30:53 »
Usually, though, if EIST is disabled in the BIOS, the CPU defaults to its lowest speed.
Anyway, my first ThinkPad, an X21, just had Intel SpeedStep technology, not EIST. I forget what the difference was... maybe EIST undervolted the CPU as well?
Offline Bluemercury
« Reply #16 on: Sat, 07 February 2009, 14:16:47 »
i have to check this......but the fact it works through a hub is weird...
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline Bluemercury
« Reply #17 on: Mon, 09 February 2009, 05:58:17 »
This is just weird, it works in the bios well.....:S
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
