Author Topic: Blank Gray Modifiers?  (Read 2864 times)
Offline CatNip :3
  • bouncy bouncy
« on: Sun, 22 December 2013, 18:10:25 »
Hello! Does anyone know where to get blank gray modifiers like the ones found on the HHKB Pro 2? I've been searching for a PBT set but no luck. So I gave up and decided to ABS. I've had a search on WASD Keyboards and found that there is two gray options, light and dark. What one closely resembles the ones found on the Pro 2?
Thanks in advance. :)
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Blank Gray Modifiers?
« Reply #1 on: Sun, 22 December 2013, 18:14:34 »
I believe you can do custom orders from signature plastics, which makes PBT caps. Can anyone confirm this/provide more info?
« Reply #2 on: Sun, 22 December 2013, 18:15:44 »
What profile are you after?
Offline CatNip :3
  • bouncy bouncy
« Reply #3 on: Sun, 22 December 2013, 18:24:26 »
I would prefer the normal. :)
Offline CatNip :3
  • bouncy bouncy
« Reply #4 on: Sun, 22 December 2013, 18:25:07 »
Thanks! I'll do some digging when I get time. :)
« Reply #5 on: Sun, 22 December 2013, 18:33:19 »
Normal?
You mean OEM?
Offline CatNip :3
  • bouncy bouncy
« Reply #6 on: Sun, 22 December 2013, 18:35:15 »
Normal?
You mean OEM?
Sorry, not to flash with keycap profiles. OEM indeed.
« Last Edit: Sun, 22 December 2013, 18:40:19 by CatNip :3 »
« Reply #7 on: Sun, 22 December 2013, 20:15:52 »
"closely resembles the ones found on the Pro 2" - are these to go on to a HHKB?
« Reply #8 on: Sun, 22 December 2013, 20:17:16 »
I assumed they were just looking for similar color for MX.
Offline CatNip :3
  • bouncy bouncy
« Reply #9 on: Sun, 22 December 2013, 20:21:05 »
For MX, yes. Forgot to mention. :/
