Author Topic: Which is quieter? Thick or Thin PBT?  (Read 2301 times)
Offline fourzeropooh
« on: Sun, 22 December 2013, 22:35:09 »
Which is quieter? Thick or thin PBT? Or are they the same loudness? Will the sound be amplified more with thin than thick?
Re: Which is quieter? Thick or Thin PBT?
« Reply #1 on: Sun, 22 December 2013, 22:36:36 »
Thin will be more high pitched, thick will be more low pitched. Thick bottoming out will be louder. Thins will make blues sound louder. There really won't be much of a different in volume, as much as the actual sound though.
« Reply #2 on: Sun, 22 December 2013, 22:41:06 »
Ah I see. Thank you for the help. I will probably go with thick.
Offline PointyFox
« Reply #3 on: Sun, 22 December 2013, 22:49:24 »
What Sifo said.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Sun, 22 December 2013, 23:04:42 »
Thick PBT
Offline elttaboi
« Reply #5 on: Sun, 22 December 2013, 23:09:35 »
I agree. They're both equally as loud. Just sounds different in pitch.
Offline Nixietube
« Reply #6 on: Mon, 23 December 2013, 10:49:56 »
the sound level will be equaly loud but due to the high and low pitched sound i am more comfortable with the sound of thick pbt. it turns the "click" into a "clack" and the bottoming out is not a "tack" but a "tong"
